LE ROCHEFORT - Harbour yacht from 1787 1:36 by Tobias (Monograph by ANCRE)
Good morning everyone.
Thanks for all the likes and comments, that gives me the courage to keep going.
Hi @BradNSW , yes, of course you can do that for the Salamander. Strictly speaking, you should. However, those aren't wooden nails up there, but iron ones.
Generally, on French ships, only iron is used up to the waterline, and then wood and iron.
@RussF , regarding your question, yes, I use a wire drawing die. I have two: one for round wire, which limits me to buying only one size.
The second one is for making square wire.
These wire drawing dies are sold in jewelry supply stores, so anyone looking for one should check there.
@GrantTyler ,
My friend, I think I wrote something about this earlier in the report. But no problem, I use "Ballenmattierung" (Ball Matting) from Clou.
What is Ballenmattierung?
Ballenmattierung is a product for manually finishing wooden workpieces. In just a few steps, you can achieve a satin-gloss surface. The surface must be dry, grease-free, and dust-free. I've tried many different varnishes, oils, and waxes. For me, the Clou product is the best. Why? For example, a treated surface can easily be roughened with sandpaper or completely stripped of its finish without leaving any residue.
Witaj
pięknie wygląda poszycie z kołkowaniem Tobiaszu .Czy to jest pokryte Colu Tobiaszu czy czymś innym Tobiaszu. Pozdrawiam Mirek
Hello, the sheathing with the studs looks beautiful. Is it covered with Colu, Tobiasz, or something else? Best regards, Mirek.
Witaj
Cześć Mirek, dziękuję bardzo. Tak, korzystałem z Clou.
Hi Mirek, thank you very much and yes, I used Clou.
Thanks Tobias. You did but I had forgotten….was too lazy to sort through 54 pages ROTF. Thanks again however I cannot get Clou here so will have to stick with linseed oil. Cheers Grant
