Fanny M - a simple lift model
When I led the Chapelle to build or not build discussion, I mentioned the classic book American Ship Models and How to Build Them by V.R. Grimwood. At that time I had gotten some Cherry wood and milled some lifts for Fanny M. As I have been working on Gracie S, in particular near the sternpost where there is a good deal of concave work with small radius curves, I started to wonder if it might be worthwhile to take a look at how Fanny M can be modeled using lifts. The hull of Fanny M is much simpler to shape due to the fact there are no concave surfaces to shape. Also, in contrast to Gracie where there was a choice between horizontal and vertical lifts, Fanny is a natural for the traditional horizontal lift construction.
According to Grimwood, Fanny M. - a Piscataqua River Gundalow - was built in 1886 by Captain Adams of Adams Point, Mass. Fanny M. was wrecked at Dover Point, New Hampshire. A few pictures of the wreck in 1925 are held by the Smithsonian and can be located on the web.
Fanny M Wreck 1 Smithsonian.jpgFanny M Wreck 2 Smithsonian.jpgFanny M Wreck 1925.jpg
D. Foster Taylor measured the wreck, and in conjunction with an original builder's model created draughts for Fanny M which appear in the Historic American Merchant Marine Survey (HAMMS). While, I haven't seen the actual HAMMS drawings, there appears to be a reproduction of such in the Chapelle book National Watercraft Collection Plans:
It is from these plans that Grimwood redrew with slightly less detail and placed in his book. The plans in the book are drawn to 1:96 scale and Grimwood suggests building the model to the scale of 1:48. That is what will be done here.
Thus the first step is to redraw portions of the plan twice as large. To construct the lifts, it is the waterlines that need enlargement. Photocopy enlargement was not the way to go as part of the plans have been lost in the book's seam! I took a sheet of poster board and aligned the bottom edge with a straightedge. Using a triangle, station lines noted in the plans were drawn perpendicular to the edge of the poster board. The edge of the poster board represents the centerline of the hull. Using the plan showing waterlines, measurements were taken, doubled and then marked on the poster board. There are 5 waterlines to reproduce. There are various ways that the needed measurements can be developed; the most basic being to measure with a ruler and then double the measurement, and without recourse to actual measurements proportional dividers can be used to double and transfer the dimensions.
I find my proportional dividers bulky to use (wish I had a smaller one), so I actually went with a third option. I took off the needed measurements with regular dividers and then used a 1/2" to 1" drafting ruler to double the dimension, opened the dividers to the need dimension (on the back side of the ruler) and transferred to the poster board. Once all the measurements had been transferred, I got out some French curves and ship curves to draw the waterlines. Here is the result:
With the waterline plans complete it was time to get some wood milled for the lifts. Grimwood informs the reader that there are 4 lifts 1/4 inch thick and 1 lift (the top) 5/8 thick. All need to be 17 1/2" long by 6" wide. I decided that I would make my model of Fanny M using Cherry wood, but the choice is obviously up to the builder! I purchased my wood as 4/4 and milled it to the necessary dimensions. Note that if you are 'experimenting' with this model / method of construction; 1/4" sheets of wood are not too difficult to come by in a number of different wood species. 5/8" may be more challenging to find, but you could get by with 3/4" material as the top lift will eventually be cut down.
Here are the lifts that I prepared using a thickness planer:
Next the five lifts were stacked to produce a squared rectangle and finishing nails were driven into the four corners to maintain this configuration. It is crucial that the resulting block is perfectly 'square'. This can be checked by using a machinist square to draw a square along all four sides of the solid - if the final line joins to the first, you are good to go - if not the block needs additional work before proceeding.
I used a marking gauge to layout the centerline along the top lift and then drew station lines using a machinist square. The center line and station lines were extended around the entire block. I also labeled the station lines to help minimize errors in transferring information to the lifts.
A quick run to the drill press came next to drill a pair of holes into which locator / alignment dowels could be inserted. In many cases, the holes will be drilled thru all but the lowest lift, so the bottom of the hull does not show a hole and/or plug. For this model, I purposely chose the locations of the holes to be that for a mounting system and drilled them straight thru.
The nails were removed and the lifts separated.
The next step was to draw waterlines on each of the lifts. Because all the waterlines come fairly close together midship, I decided to color code each.
Now I cut along the outermost waterline and transferred the shape to the top lift:
I then cut along the next waterline and transferred it to the next lift:
The process continued until all 5 lifts were marked.
The five sheets of wood were sawed near their waterlines. I used a bandsaw for this process, but it could just as well be done with a a handheld jig saw, or a hand saw. I sanded each lift to the marked waterline using a spindle sander. Again, alternative tools could easily be used - disk sander, belt sander, rasp, sanding block, ... - as is available. Please don't get the impression a fully decked out woodshop is needed to build a rather simple model ship!
This is what the lifts looked like at this point:
At this point I marked the sheer on the top lift. To do so station lines were redrawn down the sides of the previously sanded top lift. Using the plans measure up from the bottom of the top lift to the sheer, double and transfer to the corresponding station line (on both sides of the lift). Once all measurements are noted a flexible strip / batten can be used to draw a smooth curve thru the noted points.
Just a word of caution here - you cannot simply draw a scaled up version of the side plan and wrap / attach it to the lift to draw the sheer:
The reason it doesn't work is because the sideview is a projection and therby suppresses information related to the curvature of the hull in the width's dimension!
Time now to permanently affix the lifts together. Some good wood glue - I used original Titebond - and a lot of clamps is in order. Don't forget the locator pins to keep all the lifts in the correct locations. Also, cleaning up as much glue seepage is a good idea - this may need to be done several times as glue squeezes out. Clamping should be as uniform as possible and it is paramount that the edges where lifts meet are tight so no gaps show in the finished hull.
Best to leave the clamped up hull dry for several days before taking off the clamps. I left mine alone for a week.
After I was sure the glue was dry, I began to remove material from the top lift, working down toward the previous drawn sheer line. I chose to do the first stage by repeatedly running the hull over the blade in my table saw. Notice that wood was not removed near the bow nor stern; it was left to keep the hull elevated at a constant height throughout the process.
In similar fashion, some modelers mount the hull perpendicular and make repeated cuts to the sheer using a bandsaw. Chisels are used to remove wood between the bandsaw cuts. There is no reason that a multitude of cuts could not be made with a handsaw and then the remaining material chiseled out - it would be just a bit more time consuming; however, the result would be the same.
I used Shinto rasps to remove the rest of the excess material above the sheer line. This was my first experience with a Shinto rasp (made from a series of interlocked hacksaw blades). I found the tools efficiently did a fine job for this task.
At this point I decided to remove some of the interior wood - this is not uncommonly done in lift models, especially large ones. I took out material using a mini-router. Honestly, if I were to do this model again, I would not go through this process again. However, here's what it looked like after material removal, some smoothing, and a block of wood added to hold the hull in a vice.
Now it was time to flip the hull over and start working the lifts together. The goal here is to remove the excess wood up to, but not exceeding the lift joints. A tip from Bob Cleek, helped me not go past the lift joints: paint the inner corner of the joints black and shape until they are just about to disappear.
So, again using the Shinto rasps, excess wood was removed in a way that worked toward a smooth continuous surface that would display the hull lines of Fanny M. This is the stage of the build that has me classifying the build as 'simple'. All the shapes of the hull's exterior are convex - no hollows, nothing concave to worry about.
Here are a few pictures along the way - this take more than a few hours to accomplish!
At this point I switched to a sanding block first 120 grit and then 150.
Creating a deck plate was the next major task. Grimwood would have you cut a piece of wood for the deck, sand / shape to the correct camber and then scribe planks into the board. I have tried scribing in the past - it is simply not in my skillset. So I've cut the deck plate from thinner stock, it was cambered and then planked with strips of Cherry.
Here is the deck plate as I am cutting out regions for hatches and deckhouse on my scroll saw. A coping saw by itself and/or a key hole saw would work here as well.
Among many other limitations in my skill set is filing / sanding a flat line. There are a dozen to do just on this deck plate! To aid me in this process, I find clamping the workplace with a straight guide along the side to be shaped is often useful - some individuals just line the work up with the vice jaw.
The deck plate now needed to be glued to the hull. This is one of the more challenging processes to be delt with on this model. The surface that the plate glues to is curved and there are few locations for easy clamping. Looking back, because the deck was planked, perhaps mechanical fasteners would have been a good idea here. There are locations that small wood screws could have been inserted without fear of protruding thru the hull.
Fortunately the bottom of Fanny M.'s hull is flat so that boards could pass across the bottom to serve as clamping locations. At other locations spring clamps with bits of sandpaper to keep them from slipping off were used. The result was satisfactory, but I would be grateful to learn better ways to take care of this task.
Once the glue had cured - I think I left this for a couple of days in its clamped up state - the plate was faired up with the rest of the hull. Once again the Shinto rasps followed by sandpaper. Then some deck camber was introduced to the deck plate.
Strips of Cherry 1/8" wide were made up for the deck planks. To somewhat preserve the look of a scribed deck, all deck planks were laid in single strips fore to aft.
Here are some pictures of the planking process.
Strips of wood perpendicular to the deck planking is being used to hold the planks tight to the deck.
All the deck planks are in place. I've drilled holes near the front and back of the deckhouse and hatch location, because the deck was sanded smooth prior to opening the deck (and of course, the pencil lines would be removed).
Now the deck has been faired to the hull and is sanded and smooth. The next work was to open the hatch and deckhouse locations.
Deck rails as they may be called - but only a few inches in height on the actual ship were added next. Fore and aft they are made from 1/16" by 1/8" strips that had been wetted and clamped in their curved shape prior to attachment. Between are thicker rails that have a series of scuppers. I milled the scuppers, but they could be made using files, knives, hobby saws, etc.
A skeg and false cutwater were cut from 1/4" cherry and fitted. These parts as well as the scuppers are visible in the next picture.
At this point, for all practical purposes, the hull is complete. In many ways, while 'plain' the lines of this hull are not disappointing - at least to me.
Now it is time to focus on deck fixtures / furniture and then the masting and rigging. I've a start on the deck house; hopefully some pictures and update soon.
I should have mentioned this right from the start - while the National watercraft Collection holds a model of Fanny M., I have not seen any pictures of it. In fact, I have not actually seen photographs of any display model of Fanny M., nor pictures of other builds of any Grimwood models. If anyone can point me toward models associated with the Grimwood book, I would appreciate it.
Now the reason I said 'display model' of Fanny M., is that there is a full size reproduction / model of Fanny M https://www.gundalow.org/
The first deck feature that I chose to work on was the deckhouse. Choices can be made on how this can be constructed with options based on it being made solid or framed. Either way, the deckhouse can be planked if so desired. I decided that I wanted the deckhouse to be planked and I wanted open the four lights along the sides of the deckhouse. I initially was undecided as to having the deckhouse door open and / or showing any interior detail. Having this indecision led me to framing the deckhouse, thereby leaving options.
Four corner posts were made from 1/4" square stock. They were rebated to accept 1/16" planking material. Along the athwart sides a spaced board was attached. Notice that the planks on the front and back of the deckhouse are set horizontally; however the planks along the sides slant with the sheer of the deck. Thus, while spacers are straightforward to attach along the front and back, doing the same along the sides is more problematic.
To keep the four corner posts properly spaced and aligned a wood block sized to the interior of the posts was made. This allowed me to set all four posts vertically in the confines of the opening cut into the deck.
Pieces of 1/16" Cherry were cut to a trapezoidal shape that fit along the sides into the corner posts - with grain running (reasonably close to the deck sheer.
These pieces of wood were then sliced to produce the planks that would be used along the sides of the deckhouse.
Notice the pins - they were used to set the lowest plank along the deck sheer. I planked a bit higher than needed and then marked and cut the sides down to the correct height. The front and back were cut higher so that camber for the roof could be formed. Others may find it easier to plank to just the needed heights.
Once the sides were cut down and the roof camber sanded, it was time to deal with the lights / windows. It should be noted that the size and location of the windows are slightly different in the Grimwood plans as opposed to the HAMMS plans; the HAMMS locations / shape of the windows seem to be closer to the photographic evidence from the wreck of Fanny M. I have attempted to place the windows closer in height to the photographs, but I believe that mine may be not quite the same height. My windows are 1/4" wide and 1/8" high; they are placed so the 1/8" height matches with a planking strip, thereby making it easier to cut all the windows to the same height.
I marked the location of the windows on the deckhouse and then drilled several holes in their interior to help with material removal.
I used a mini-chisel to remove a good deal of the center material and then used a scalpel to trim out the rest of the material. In the past, I often used a small file for this type of work but now I find I can produce flatter edges and sharper corners with a bladed cutting tool.
The roof comes next, but it seems that some wood needs to be prepared to do so - time to mill some more 1/16" Cherry!
I had time today to mill the 1/16" Cherry, along with some 1/32" material that will be used soon. The 1/16" material for the deckhouse roof was ripped into planking strips 1/8" wide and a bit longer than needed. Before attaching any of the planks, I made note of where the deckhouse door was to be positioned. From the plans, the door together with molding was 3 feet - so 3/4" or 6 planks wide for the model. Starting at the middle of the deckhouse, 6 planks were attached with their edges flush to later accept the door structure. The other side of these planks went beyond what would be needed; i.e., no effort was made to have them have the correct overhang on the front side. This is another example of what Dave Stevens spoke about in his Sir Edward Hawke build - build big and then cut to size. The remaining roof planks were then added, each having excess overhang on both sides. I should also note that the outermost plank on each side is wider and will later be cut to the correct width / overhang.
Here is what the roof looked like at this point. Sanding / smoothing the roof came next. A nice thing about having the excess wood at this point is that when sanding the roof there is very little chance of rounding off material at the (final) edges due to sanding block rocking.
I chose to trim the side overhangs next. Some would say doing front and back first may be a better order of work in the event there is a (small) amount of breakout from working across the grain.
I wanted a 1/16" overhang on all four sides and used a strip of wood this thick for a trimming guide. Along the grain, the guide strip was clamped and the wood was trimmed with a sharp utility knife.
Across the grain a fine toothed hobby saw was used. Here I used tape to hold the guide strip to the deckhouse and then positioned the sawblade tight against it to get a straight cut.
The result:
Sitting on the hull, the deckhouse is starting to look nice. Still to be added is the door / entry system, stove pipe, and a scuttle.
The door / entry to the deckhouse has gotten a little attention and should be finished soon. Here is a construction photo of how the work is being approached. The sliding roof guides are from 1/8" square material with a 1/16" square removed to make L shaped material. I removed the material with two cuts on a Byrnes saw using a fine slitting blade. Because these pieces are just 1 1/2" long, the inner material could be removed easily with a hobby saw; else, the L shape can be built from a piece of 1/8" x 1/16" strip and a 1/16" x 1/16" strip. I glued these in place to match the opening left when creating the deckhouse roof. Also, sitting across the guides are a couple of pieces of wood that have been contoured to parallel the deckhouse roof and serve as a foundation for the sliding roof.
Next the vertical door frames were added, as well as a lower ledge. Not easy to see, 1/32" 'door panels were added between the frames. 1/32" thick material is being used to model the panel framing within the doors themselves - the horizontal strips will come next.
The sliding roof came next - 1/32" thick planking strips cut to a width of 3/32". Since the rails were already secured to the deckhouse roof I knew it would be difficult to make any modifications on the back edge of this new structure. So the location of the back edge was marked on the rails and a flexible strip was clamped along the marks to form a boundary for the planks.
Once all the planks were attached (middle ones first) and the adhesive dry, the structure was smoothed. I then cut off the excess in the front in a way similar to how the deckhouse roof planks had been shortened. Finally, the door was sanded smooth. In retrospect, it would have been better to have smoothed the door / door frame before adding the sliding roof :)
Two more tasks before the deckhouse is attached to the deck / hull - stove pipe to the left of the door and a small scuttle to the right.
The little scuttle was constructed from 1/32" thick material - there are three planks that go athwart.
The stove pipe was made from 5/32" copper tubing. The portion that extends from the roof was blackened using a product called Brass Ager that I found on Amazon. This is the first time I have used it and I think I may like it more than Black Brass from Birchwood Casey. It seems quite similar to how I remember Blacken-It. The end of the tube was dipped in the solution, neutralized in cold water, and buffed before installing. The piece of tubing was cut so that a significant portion is below the roof (and touching the side). It was CA'ed in place.
The biggest challenge of this part is to get a nice hole for the stove pipe to pass through. The center location was noted on the roof and a small diameter drill bit was passed through. It is common for individuals to enlarge the hole using successively larger drill bits. I use that technique often, but when I want to make sure there is no tear out from bits, I will often use a set of reamers to open the hole.
I received the reamers as a 'gift' from Model Expo years ago, and when I first got them, I was wondering what they would ever be good for. It turns out that they are a lot more useful than I expected. In particular, they are much easier to control than drill bits for fine work and will likely keep you hole (more) round than using a needle file. In some cases the reamers can be 'twirled' with your fingers; however, it is often worth the time to place them in a pin vice prior to use.
The deckhouse is now essentially complete - perhaps some door knobs yet. I will likely set it aside now so there is as much working space available as possible as additional deck detailing takes place.
Greg,
After reading about your use of the reamers, in the interest of: I would rather have a tool and not need it, than need a tool and not have it ;) I went up on TEMU to check on low cost reamers. While there - I thought about what I would do if the hole that I drilled had the exhaust pipe rattling in an over large hole. I then thought paper collar. Then I thought: hot metal pipe, tight fit, wooden roof - char or fire? Then I thought loose fit, insulate from the wood, but what about rain? What tech did they have in 1886? Do you think they had double wall sheet metal? Was it Asbestos? Clay? Mica?
Quite elegant job so far. Black Cherry really does itself proud in closeup photography, doesn't it? No fuzz, no cavernous pores, crisp edges.
Greg,
I would assume (and everyone knows that assumptions often are not correct!) that something similar to what would have been used in a house / shanty heat pipes could have been employed for the stove pipe exit on a ship. When I first saw pictures of stoves on ships, my first reaction was - how do they keep the ship from igniting - then I re-centered and just noted that a lot of house (and other buildings) are made from wood and they have stoves and furnaces. So I then 'guessed' that the technology was similar since fundamentally they are all wooden buildings. Maybe someone else knows more!?
I'm not sure how I would have 'fixed' too big a hole for the stove pipe - it would depend on how much slop there was. The most complicated solution that I could think of was to build a floor for the deckhouse with a stove to sit on it as well as to hold the stove pipe up.
I do like working with Cherry, it is easy to mill and work with; it glues well, takes a finish well, and it also doesn't have a bad odor when sanded. I assume all of these qualities have played in why it is a furniture and cabinet favorite. While many modelers like the yellow and pink wood tones, I do like the darker tones of this species for a model. When it comes time, I will be finishing this model with Linseed Oil which will darken the wood.
I picked Cherry for my first scratch built model because it was readily available to me at a good price. I didn't know if I would make it through that model and/or how good the result wood be, so I didn't feel it was appropriate to potentially waste a more expensive sought after wood on the project. That project did work out OK, but I still like Cherry and don't always feel the need to reach for other species. To this point, I've only received one negative comment on my use of Cherry - a viewer on another forum criticized my use of Cherry due to the more obvious grain than that of Pear / C. Boxwood, etc.
I will continue to use this type of wood and have no reservation recommending the use of Cherry, but at the end of the day it is the individual modeler's choice and preference.
I would probably glue a scab covering the hole at the underside of the roof for the pipe to sit on.
Rather than modeling what could be in the interior of the deck house, I would use cellophane or glassine paper as glazing and offset black paper behind it.
The location of this model's stovepipe is tight up against the interior wall; so I just opened a hole and glued the pipe to the wall. If the pipe had been away from he wall, I would have done similar to what you suggest; else a block would have been added below the roof where the hole was to be drilled, with the hole extending into / thru the support block to provide a larger gluing area and a better opportunity to have the pipe fixed in the correct vertical position.
I hadn't planned / won't be modeling the interior of the deckhouse. I prefer a 'balanced' approach to my models. Here the major goal was hull line representation together with major deck fittings. I don't think an un-planked / lift based hull is consistent with a fully detailed interior to the deckhouse. This also had influenced my decision to keep the deckhouse door / sliding roof modeled in their closed positions.
I'm still open on any treatment of the windows, currently I'm leaning toward leaving them just as they are - open holes. If you peer into one of them when the deckhouse is in place, there is nothing but pitch black to see. If anyone asks, I can argue it was a hot day on the river and all the widows had been opened/removed for a bit of a breeze!
