L'Orenoque Mamoli 1:100 scale
Paul, I don't know what internet you are using, but in my universe no supplier sells dowels made of "swiss pear, castello boxwood, Buxus macowanii (boxwood from South Africa)" I went with limewood. Please tell me I made a good call :eek:
If you look at my post I spoke of 'similar species'. Limewood is basically basswood. It is a soft wood but if you don't stain it it will be a nice creamy color which I believe is what you are looking for.
It is European limewood - the internet said that it is a hardwood.
In addition to what Paul mentioned, you can make dowels from virtually any type of wood as long as you start with square stock. With a simple jig, even a basic drawplate setup, or using a threading die, you can produce dowels in almost any diameter you need. It’s a very practical solution if you want control over the wood species and grain. I just hope my search engine history (below) still has those instructional videos saved.
Martin! Thank you! Yup - Re-do here we come!
If memory serves (I'm on campus and don't have ready access to the plans) kit-plan gives 5mm for fore and main and 4mm for mizzen. Any other dimensional information re: spars on those plans? Where am I looking and what words am I looking for? I think my L'Orenoque plans may have some info :)
Blessings.
Chuck
my cutty at 1/115 was running 6mm , i generally use 8mm at 1/50-1/65 and 7 on 1/78-1/100 . Let us know when you get to see the plans.
I hate re-drilling mast holes, i wish you luck if that's what you are up for !
On the right hand side of the sail plans , the last column is marked diametre, masts are "mats", but be careful because what we would call a foremast is "misaine", while what we would call a mizzen is "l'artimon" ! Yards are "vergues" , except gaff spars, "cornes"
i have rounded out slightly, no idea what you can find over there, is it all imperial or can you find metric ?
topmasts 4, mizzen topmast 3
main yards are 4.5mm, topsail yards 3.5, topgallants 2
gaff spars 2.5 gaff topsail spar 2
jib boom 3
Jim! Thank you! The google search worked!
Blessings.
Chuck
jib boom 3
Thank goodness for my spirit-guide on this build! Martin!!! Thank you! I can almost get by with very basic conversational French - serves me right for not following through with French - although I was quite smitten by my 7th grade French teacher:cool:
I can (and just spent $100 for overnight delivery - impatience) get metric.
Blessings. Peace. Gratitude.
Chuck
jib boom 3
Martin! I'll reach out after a thorough review of the plans. New mast holes are definitely in the picture. Also I need to finish the bottoms (heels?) of the replacement masts with tenons that fit the mast steps I lovingly fitted before the hull was plankedROTF
I should have asked/confirmed - you are reading from the Magellan/Isly plans?
Could you not find maple? You should also be able to get walnut dowels online, I use those for sheaves in blocks. I don't think you'll get large diameters like .75+ inch, but .5 inch and smaller should be available.
Who makes spars from dowels anyway?
