I think you're absolutely right, thanksThe two sets of holes, one lower and one upper. The lower set takes the large rope that goes through the tackle around the back of the cannon and back to the hull on the other side.
The second set is upper and on each side of the cannon there is a rope harness(smaller rope) with blocks that attach to the hull. The large rope was used to prevent the cannon from flying backwards across the deck. The main ropes were for putting the cannon back in place after it was packed and ready for fire.
I’m with you. Quickly glancing at a paper plans and being able to get scale measurements in a second is easier than poking around on a device, re-awakening it when it goes to sleep, etc. but am I the only one that has ever pinched to zoom on a hard copy of something?? Ha ha. Yup.I think the CD for instructions is OK, but I would still want a set of full size plans for mounting on wall to view and compare against.
Looking at blow ups of plans has its advantages for sure, but I like paper copies as backups.
