I think you're absolutely right, thanksThe two sets of holes, one lower and one upper. The lower set takes the large rope that goes through the tackle around the back of the cannon and back to the hull on the other side.
The second set is upper and on each side of the cannon there is a rope harness(smaller rope) with blocks that attach to the hull. The large rope was used to prevent the cannon from flying backwards across the deck. The main ropes were for putting the cannon back in place after it was packed and ready for fire.
I’m with you. Quickly glancing at a paper plans and being able to get scale measurements in a second is easier than poking around on a device, re-awakening it when it goes to sleep, etc. but am I the only one that has ever pinched to zoom on a hard copy of something?? Ha ha. Yup.I think the CD for instructions is OK, but I would still want a set of full size plans for mounting on wall to view and compare against.
Looking at blow ups of plans has its advantages for sure, but I like paper copies as backups.
Your thought on how they should be rigged are mostly spot on, some question the rotation angle of eye bolts in bulkheads as different navies and countries did it differently, and did the breech line go to top set or bottom, I am not sure, and how the breech was wrapped abound the back of the cannon differed on designs over the years. If you have time, space and blocks, most main cannons had a line at the rear to pull the cannons back inboard when they were not needed for firing.After further investigation and finding no definitive way to rig the cannons, and not being persnickety that everything has to be 100% accurate, I will rig them using all four holes I drilled in the bulwark, two will be for the breech line and two for the intake lines, (maybe it is outhaul) but basically I want to make it look pleasing and not a bunch of oversized blocks and knots. I will post a picture once I have one assembled and in position.
Nice Robert!so what I have found out there seems to be a dozen ways to rig it. So I went with something easy and looks good for me. There is a breech line wrapped around the cannon end and fastened with an eyebolt to the bulwark, one inhale line and two outhaul lines also fastened with an eyebolt to the bulwark. I placed the outhaul lines outside of the breech lines. View attachment 584878View attachment 584879View attachment 584880
Great decision.I'll change the ones provided in the kit with the smaller 2 mm. blocks
Thank you Allan, but as I decided to spend some money changing the blocks, I think I'll keep the cannons provided by the kitGreat decision.
British ships used pairs of single blocks, according to The History of British Sea Ordnance by Adrian Caruana, for all cannon smaller than 32 pounders. Do you or does any member know if this was the same for Spanish ships? I cannot find any contemporary models, supply lists, or drawings showing this one way or the other.
If you or anyone would like 3D drawings of Spanish cannon used at the time of Santisima Trinidad let me know. They can be used to have guns printed in any size in resin. At your scale I have been paying less than US$1 each, including shipping (within the US) I realize many members prefer metal guns, but casting them to show the details can be difficult at best.![]()
2D drawing
You paid good money for them so totally understand your decision to use them.I think I'll keep the cannons provided by the kit
Good morning Enea. You most certainly be satisfied with those little boats. Cheers Grantresult that seems satisfactory to me
