La Venus
Well after finishing my semi - scratch HMS Victory (POB) a couple of years ago I was starting to get a little bored in my retirement. So I have jumped right in at the deep end after seeing so many magnificent arsenal models and decided to build the French Frigate La Venus from the plans published by Ancre. The model is 1:48 and the frames, keel etc are in lovely dark Swiss pear from hobby mill.
Here goes ……..some pictures of work to date.
Yes, having completed all 63 frames, keel, false keel etc I’m at the point where I need to think about putting these parts together for real. Currently doing a bit of research as to the best type/style to make.
If you poke around on the scratch building side of the forum you will see some active builds that might provide some food for thought. You might also look around for a copy of this book: The Art of Ship Modeling (Bernard Frolich). You can get it new from Ancre but it's spendy (especially with shipping, etc.). Perhaps there is a used copy somewhere?
Some examples of active builds:
There is also a link in my signature below to my stern section model, but the scope of that project is limited compared to yours.
I'm new and learning so I'll pull up a chair. Looking forward to your build.
Thanks for the links Paul, I’ll take a look. I have Frolich’s book and also Ed Tosti’s “The Naiad Frigate” vol 1 which presents a slipway he built which looks pretty good.
Hi Tobias, yes I am aware that there are some errors in the plan set from Ancre and will try my best to sort the mistakes as and when I come to fitting. I think this will undoubtably mean some rework!!!
Hi Jon!
Very nice progress so far, and I'm following your build with great interest. I hope you enjoy building the Venus, despite the anomalies in the plans.
My build log of the Venus in 1:72 scale is unfortunately only available on the neighboring forum www.segelschiffsmodellbau.com
If you have any questions, feel free to contact me anytime, and I'll be happy to help.
Best regards,
Andreas
Many thanks, I’ll definitely be checking out your build. I haven’t been able to find too many model shipwrights on line who have attempted La Venus…..maybe I’ll find out why as the build progresses!!!!
Jon
Hi, great work, it looks well done. It's true that Venus are rarely seen in construction logs. I'll keep an eye on it.
Miguel.
I built the Venus in 1:96 scale and can confirm that the stern is not accurate and shows a major error in the arrangement of the fins. Gerard Delacroix pointed this out to me.
Many thanks for pointing this out. I ‘m very much hoping that I’ll be able to figure out some of the, what appears to be, many of the inaccuracies in the Ancre plans. Maybe I’m just making a load of expensive, but very nicely shaped, fire wood. Only time will tell!
Hi Andreas
I have studied your build log and that posted by Willi in the same forum…..absolutely superb workmanship by both of you. The logs contain some every useful information and highlight the pitfalls of the planset. An interesting challenge ahead!!!!!!!
Cheers
Jon
Hi Jon!
I'm so glad to hear that, thank you so much! Willi built the Vénus before me, always helped me with any questions, and was a great help.
I'm really looking forward to seeing your further work on the Vénus and wish you lots of success and enjoyment.
Regards
Andreas
After much scratching of head, careful measurements of various plans and review of methods of making a building jig I have bought the relevant materials. From my research I figured the best Ancre plans to use will be relevant cut outs of PL. XV for the lower jig board and PL. I for the top board.
I have marked up PL.I with the frame numbers associated with master lines which hopefully will allow me to aline the boards after I have cut out the hull profile!!!IMG_4744.jpeg
I have marked up PL.I with the frame numbers associated with master lines which hopefully will allow me to aline the boards after I have cut out the hull profile!!!View attachment 582804
Are you going to mount the main wale?
Do you care if water between the bends cannot move from port to stb. and back? That is - Does it matter to you if the deadwood is continuous along the whole hull?
