Pavel Nikitin - Santa Maria
Lower Transom planking Port side:
I started by being a bit more agressive "fairing" this part of the frame.
The next step was to remove the char, lightly sand and glue the planks together as one piece.
Then a few dry fits to get a good fit.
Followed by a final check for a bit of overlap.
With a "filler" piece added the plank assembly was glued in place.
Today is a repeat for the Starboard side.
Jan
That's great instruction for those who are considering this as a build.
Working on odd bits while waiting for a shipment from Pavel's store.
I found a minor problem with assembling this part.
The plan:
The Parts aren't all cut the same
The problem:
Two parts fit but the third part is a bit of a problem.
Jan
Interesting ... the drawing of the flat shows the parts in the correct orientation - it appears that between there and the laser, one part got flipped over. Does the odd section have the rectangular laser marks on the reverse side?
Yup, that section has the laser marks on the reverse side. It doesn't matter how I try to fit them, one side winds up odd.
Jan
Hmm, since I could not work on the crows nest I moved on to do some deck planking.
Another "Gotcha" moment.
The instruction manual page showing the deck pieces.
The pieces from the kit, sanded and shaped.
A screen shot of Pavel's YouTube video showing the same pieces.
The problem:
The bottom left hand corner (Blue arrow) is filled in on the YouTube video, but missing in the kit instructions and actual pieces. Looks to be a Laser programing error.
I'm going to go with the video version and fill in the small gap.
Jan
