- Jun 2, 2025
Do I wind both in RH direction when both are twisting ?When the 10% is reach, both machines must turn, like I explain in the document and in the video.
Yes. The switches are so constructed that both need to have the same stand. "I" for RH rope or "II" for LH cable.Do I wind both in RH direction when both are twisting ?
The reason why the last part of the rope looks loose and why you needed to go to 13%.I missed that. All the rope I’ve made so far I did not spin the wiel when I did the last wind with the Bok. And the ropes turning out awesome
I saw those arguments and discussions on the German forum as well. One person makes rope using a free spindle, while the other uses a motor, just like me. The text and video I’m including with the machine refer to this specific machine. I support this method because that’s how I do it, and it delivers good results. It’s the way Ohla Batcharov explained it in her descriptions, and that’s the method I adopted back then. It’s the same as someone designing a vertical one, or an endless rope walk. But you’re welcome to do it a different way. All methods are fine as long as the rope turns out well.@Steef66 I guess also with your machine it would be possible to use a rolling swivel instead using the 2nd machine, correct? In my experience, better said with my setup I need the second motor explicitly for smaller rope everything above 0.6 mm works with the rolling swivel, what is a bit easier then.
Tolle Erklärung und nich bessere Umstzung. Es lohnt sich immer auf deiner Seite zu stöbern, zu lernen und zu schauen. Tolle Modelle, super Erklärungen, weltklasse schöne Modelle (Ergebnisse). Deine Oberflächenbehandlungen suchen seine Gleichen. Danke fürs Zeigen.Wie ich bereits schrieb, wende ich beide Methoden an, und es lohnt sich, es mit Ihrer Maschine auszuprobieren. Es gibt kein „oder“, es könnte einfach eine zusätzliche Option zum Testen sein. Der Vorteil der Freilaufspindel ist, dass sie von selbst anläuft, sobald die Spannung stimmt.
Mit 0,8-mm-Trimmer und 1,2-mm-Kabel mit Rollwirbel (freilaufende Spindel) erhalte ich seit heute das gleiche Ergebnis mit Motor :-D
You can compensate that with the steelcable, but 3 mm. will not make a problem.Over a distance of 6.5 meters between Bok and Weil. I’m 3mm out.
I don’t understand where you got that info from.I don't quite understand the situation.
According to earlier descriptions, you were supposed to make very small ropes because they looked bad on a planetary Domanoff, and that was the problem.
Now, you're still making large ropes.
What's the point?
Yeah I’ve got a large spare room that’s 6.6 m x apx 4 meters.You can compensate that with the steelcable, but 3 mm. will not make a problem.
I'm jealouse about the space you have.
