- Jan 2, 2022
Thx Mike. Not too closely though, eh? (sometimes I cut a corner, or two)Welcome back to the build Tim. I will be watching closely! Magic Mike
It is not correct that Columbus had no artillery on board during his first voyage. In his ship’s log, lombards are explicitly mentioned repeatedly. For example, Columbus writes on 7 October 1492 that the caravel Niña fired a shot from a lombard to signal that land was approaching. Lombards are also mentioned several times later. On Tuesday, 18 December, the feast day of Santa María de la O (the Annunciation), the Admiral ordered numerous lombard shots to be fired. He further reports that when a cacique departed, lombard salutes were fired in his honor.I did some research, and it's unknown if Columbus had cannon on his ships. Some say the Santa Maria (the large ship) had 4 cannon. Some say none. There's no proof, yet, either way. I'm guessing if they did have em - and that they were swivel cannon - large rifles if you will, mounted on the gunwales. Putting holes in the hull for cannon on a mission crossing the ocean into the unknown - I can't imagine they'd' do that.
Into the unknown? Actually, there were rumors sourced from fishermen and whalers, about the new world - rumors because nobody wanted to reveal the locations of their fishing/whaling grounds. And some books say that cod fishermen were working the St. Lawrence area some years before Columbus got to the "new world".
Anyway, I think they woulda used some cannon though, because - cannon existed at that time - they were new tech and difficult to manage - but they did exist - and they served a vital function other than defense - signaling over long distances. Hmmmm.
Particularly interesting is the entry following the construction of the fort on 2 January: Columbus writes that in the morning he went ashore to take leave of King Guacanagarí. On this occasion, he demonstrated the effect of a lombard. He ordered a gun to be loaded and fired at the side of the stranded Santa María. The king was able to see how far the projectile traveled and how it pierced the ship. A stone projectile is explicitly mentioned, whose flight was visible. The reference to a stone projectile in particular suggests a gun of larger caliber, rather than merely falconets, which normally fired lead-sheathed metal balls or cube-shaped projectiles.
Thx Mike. Hey, I see that you have built a lot of models. Wow. No - wait a minute - always finish reading first - and I see that you have about 6 more models waiting on the shelf than I do. (I also have that Model Shipways "Pride of Baltimore" waiting on my shelf). Anyway - cheers.Love the crows nest Tim! Magic Mike
Hi Tim,Making it all very interesting. What type of gun(s) he had? I don't have an opinion on that - not enough evidence for me on that.
However, it's common sense that he would have had the latest tech on board - navigation, sails, food storage, medical and military - all the latest gadgets (same as we'd do). And they did have guns at that time - so yeah, Columbus carried something that fired rounds, on his trips. Maybe a lombard.
Have you actually sourced/read the written records you mentioned? If so, I bow to your knowledge on this subject.
Thx for the history with your sources. Fascinating. Gives my reading some focus.Hi Tim,
The primary source is the Bordbuch des Christoph Kolumbus, which can be found online. If you truly wish to explore this subject in depth, I would recommend consulting the works of Monleón and d’Albertis, as well as Arantegui, who described the evolution of Spanish artillery in considerable detail.
Since Columbus mentions only the term “lombarda,” which can be understood as a rather general designation, unfortunately he does not provide detailed information about the number or composition of the artillery carried aboard his vessels.
I am currently working on a drawing of the Santa María based on Monleón’s sketches, and at the moment I am focusing on the reconstruction of her artillery. In some respects this task is simplified by the fact that it is known that the first reconstruction of 1892 carried two bombards and six falconets aboard the Santa María.
Nevertheless, I am inclined to assume that the original ships of Columbus, for example the Santa María, may have carried either up to four bombardeta, or alternatively two bombards of larger caliber, along with six falconets. On the Pinta and Niña, it is most likely that lighter-caliber weapons were carried — two cerbatanas and two to four falconets each.
Good morning Tim. I share your pain. Non the less those 2 shroud blocks look awesome . Very cool “helping “ hand you bought.I do not like working 1:65 scale. Especially the rigging. My first two mainmast shroud blocks, ready to pin to the deck. Took me about an hour to make the 1st - working out how I wanted to do it. About 45m for the 2nd. Geeze!
The ropes are spliced (with CA-) on the tops of the blocks. First, I looped some 0.4mm rope through itself around the ring, pulled it taut, and secured it with a tat of CA-. Then I seized it with 0.15 rope, using common whipping, moved the seizing into position, pulled it tight, and secured it with a tat of CA-. Snipped off the two ends. And finally, wrapped the two remaining ends of the 0.4mm rope sticking out past the seizing, around the triangular block - using CA- to splice the rope at the top of the block. For the splice, I laid both ropes into the groove on top of the block, applied CA-, then sliced off the extra with my xacto blade. To make it look like a tightly spliced rope there.
And here's why 1:65 scale is my least favorite to model in ... the sheer impossibility, of these fingers, seizing and tying up these tiny ropes, into something presentable ... and yeah, of course, I've always got two tweezers on hand.
If/when I ever finish this ... and I have dropped the Pinta 2x before ... I will stick to 1:48 or larger scale ... 1:30 and 1:24.
I did order a better helping hand ... this was $26 at Amazon. It should decrease my frustration a bit.
Compared to what I've been using for years now. Nothing stays put.
Maybe it will help, a bit.
Cheers.
Hey, thanks. The "hand" arrives tomorrow.Good morning Tim. I share your pain. Non the less those 2 shroud blocks look awesome . Very cool “helping “ hand you bought.
Cheers Grant
Glad to hear that. Thx. It's well built, and works like a charm.Tim, you will love the new "hand". You are doing great work! Magic Mike
