Muscongus Bay Lobster Smack from Model Shipways by DocTom - Build Log
Post 9 - Chainplates and Cleats
It was a glorious weekend here in New England, so most of my time was spent outside, in the yard or on my real boat. I did manage to make the second chainplate (and center the holes much better) and install them both. I bent them before installing them 2.25" behind the trail boards. I marked and drilled holes using a #70 drill bit, and trimmed the brass nails before inserting them. They are only going through the sheer strake, so are mainly there for show. I used CA glue to attach the chainplates before inserting the nails.
I then cleaned up the cleats using diamond jewelers files. They did a great job. You can get a set of 5 different shapes very cheaply on Amazon.
I sprayed them with gray primer, and then painted them with Folkart Metallic Nickel craft paint, hoping to mimic galvanized iron. My research indicated that bronze was also used, but I that seems excessive for a working boat. I understand the iron would eventually turn black, or be coated in tar, but I think of my model as a boat fresh off the "assembly line," as it were. Plus, I like the color.
I used 5 minute epoxy to attach them. I'm glad I did, because it took some fiddling to get them where I thought they should be. I did the bowsprit cleat first, as that seemed easiest.
I tried to line the side cockpit cleats with the top of the deck over the wet wells.
I very slightly bent the base of the cleat over the tiller, as recommended in the instructions. It didn't need very much. The final result:
The instructions have you attach the turnbuckles now, but I can't think why. They will only be in the way and continually fall off. I will add them at the appropriate time during the rigging. However, I will clean them up and paint them now, before moving on to the mast.
Post 10 - Spars
I spent the last several days making the final wooden pieces of the model, the mast, boom and gaff. I first cleaned up and painted the turnbuckles using a jig made of pins, scrap basswood and a paint stirrer
The mast pointed up one of the recurring issues with these Model Shipways kits - the supplied parts don't always match the plans or the instructions. My mast is several mm taller than the scale drawings, and the hole for the eyelets are in completely different places:
The holes, however, match the pictures in the instructions, so I did not change them. I decided to leave the extra height alone. On my previous model with a mast (the Model shipways Norwegian Sailing Pram) I used sandpaper to shape the spars. However, after reading a post by @Bob Cleek exhorting us to use sharp objects to cut wood and sandpaper to make final adjustments, I made the rectangular mast 4 square with a mini Stanley plane, finishing off with sandpaper. It made lots of nice curls!
This was relatively easy, as the two flat sides (with the holes) are wider than the tapered, laser-cut sides. I took equal amounts off each flat side until it was square at the foot, and then began to taper the distal end, based on where the taper began on the laser cut sides as well as the plans. I used a digital caliper to monitor my progress. I made it 8 square using a spoke shave that is part of an old Xacto set I picked up cheap on Ebay.
I think it's from the '80s. Lots of scary looking sharp implements! And a really great sanding block!
It worked like a charm, and made more skinny curls.
I started to round the mast in a vise, as recommended, but it felt like a set up for a broken mast, so I rounded it by pinching a piece of 220g sandpaper and rotating the mast by hand. Ended up pretty round
And it fit snuggly in the hull
I carefully glued on the stay cleats (I don't know how I did it, but I did, and cut them as well - St. Rosalie came through again).My initial plan was to stain the mast, but then I saw @JacquesCousteau's picture of his painted mast, which I really like. Some quick internet research indicated that Muscongus Bay lobster smacks usually had masts painted white (to be seen in the fog) except for where the hoops for the mainsail were. That area was usually unpainted, but treated with something like pine tar and linseed oil to protect the wood. The boom and gaff were usually white, sometimes with black tips. I decided to do that. I used the plans to determine where the sail would be attached, and painted above and below that Warm White. I used the Tom Lauria paint/stain technique with DecoArt Faun mixed with a little FolkArt Camel craft paint to simulate the unpainted wood. I shellacked the unpainted areas.
I will add the halyard cleats tomorrow. I'm still deciding if I should glue on the eyebolts, or wait until after I have attached the blocks. I'm thinking of buying the new interntally stropped blocks from Syren, but need to determine the size and configuration.
I then made the mast hoops
Although the instructions don't mention this, I may try to soft solder them as practice, and paint them brown to look more like wood. I know I will need to learn how to hard solder one day.
On to the boom and gaff. Again, discrepancy between the instructions and parts supplied. The instructions show spars of even diameter until near the end, but the supplied parts start to taper about 1/2 way down the spar. I decided to do an even taper along the length of the boom and gaff. The boom was a challenge to make 4 square, as the width was wider than the height. This meant I had to plane all four sides - the laser cut sides nearer to the jaws, and the flat sides nearer to the end. After rounding it I added the very small and very thin stop cleats (again, through the intercession of St. Rosalie - she never lets you down!). The gaff, like the mast, needed to be thinned down along the entire length of the flat sides before tapering. I ended up with two very nice looking round spars.
Another Model Shipways WTF, the plans show stop cleats on the gaff, but there are no supplied parts, and they are not mentioned in the instructions. Why don't they take the time to clean up the printed matter to match the kits?
Anyway, my mini drill press made quick work of the holes for the parrels.
Tomorrow I'll prime and paint the boom and gaff, and then go to Michael's in Pittsfield to buy black seed beads for the parrel trucks before contemplating making the mainsail.
This was my first experience making round spars from rectangular wood, and I really enjoyed it. As has happened over and over with me, I was intimidated by a new technique (using a plane), but once I had the wood and tools in my hands it was easy. My thanks to @Bob Cleek for prodding me to do this.
Thanks for dropping on.
Post 10 - Spars
And wasn't it nice to just sweep those shavings into the wastebasket instead of having turned them into fine sawdust that spread all over everything in your entire shop? ;)
You're certainly doing a great job of it! It makes me feel good to see that somebody has benefited from a tip I gave them. The care you are taking with your build really shows. That's really what ship modeling is all about: a collection of separate tasks done carefully!
I'm always worried that my offering a suggestion will annoy the recipient, but I'll offer a couple more and you are free to ignore them if you wish.
First, you expressed some frustration with using copper wire. Actually, it's great stuff for the tasks you've tried to use it for, but the problems you are having are the result of your using wire that's much too large. Think in terms of scale. For stropping blocks, try to find some very fine copper wire. (You can do the math and get a measurement if you want.) Sometimes copper wire is hard to come by, but for stropping blocks the size you are working with, you can always get some "telephone" wire, the stuff with the multi-colored insulation that often comes in huge bundles of wires for big office phone systems. (Back in the day when everything was hard-wired.) You can then strip the insulation off of the copper wire and you're good to go. A yard of that stuff will keep you in copper wire for the rest of your modeling career! I think the gauge is 22 or 28, but I know it's the diameter of a #78 drill bit because that's what I always use to drill holes for it. If you can find some thinner copper wire, so much the better. The properly scaled wire will be much easier to work with than the thick stuff you've been using.
If you haven't gotten one yet, you should buy a jeweler's "bail making pliers." They come in various configurations and sizes and they're cheap. I like the "stepped" ones pictured below which will make a range of diameter rings on one pair of pliers. If you don't have "bail making pliers," you can also take a properly sized drill bit and wrap the wire around the shank to get a perfectly round "eye." With fine wire, you can make eyebolts by twisting the "pigtails" with a pliers around with the wire bent around a drill shank and nip off the end leaving the "shaft" of the bolt (the twisted pigtails). This will actually form a bit of a thread that permits the eyebolt to be screwed into a properly sized hole with a drop of adhesive. If you want to "fake" a mast band, you can glue a strip of black construction paper around the mast and then drill two holes through the paper into the mast and glue a "U" shaped piece of wire into the holes. It will look just like a forged mast or bowsprit band when you are done.
Now, one reason I prefer copper is that it is soft, unlike brass or ferrous metal, which can be springy. That makes it easy to work with. If the copper you have is too stiff, you can always anneal it by heating it until it starts to glow, then quench it in cold water. It will then be soft and easy to bend when it's cooled. (Copper will harden if it's "worked," i.e. bent or hammered. If that poses a problem, just anneal the piece again as your work progresses, although annealing shouldn't be necessary for stropping blocks or making eyebolts.)
The other advantage of using copper is that it can be left to oxidize and over time (a year or more) it will turn "penny colored," which is perfect for portraying bronze fittings. (Shiny brass is never used for marine fittings, despite what the kit manufacturers would have you believe. The only brass on a ship will be decorative trim, like binnacles, clock and steam gauge cases and indoor handrails. It's too much work to polish!)
To portray wrought iron on period vessels, which doesn't rust, but rather turns black, copper can easily be "blackened" using liver of sulfur. This is a chemical familiar to jewelers which is diluted in water and can be painted onto clean and bare copper. It leaves no residue surrounding the copper when the water dries, so you can do all the copper fittings on a painted spar and then "blacken" the copper fittings and they will look perfect, unlike painting fitting which is a tedious exercise that often makes a mess. Check out YouTube for "liver of sulfur" and you'll find instructions for its use. It's readily available from jewelers' supply houses. (There are other "blackening" chemicals, such as those used for "bluing" firearms, which can also be used but they can be trickier to use than liver of sulfur.)
Now, to really make you crazy, I'm going to suggest that you take a pass on using wire rings for your mast hoops. Mast hoops in real life are made of wood. Metal mast hoops would tear the mast up and to prevent that (as is done on bowsprit headsail tack messenger hoops) if they were metal, they'd have to be covered with leather sewn on with a baseball stitch. Here's how you can make real wooden mast hoops very easily, believe it or not.
Take a short piece of softwood plank a foot or two long and an inch or so thick. Pine or poplar would be fine. Stick it in a vise with the long edge up. Determine which way the grain is running and plane off long, thin shavings with the grain using a sharp plane. (Which is how you should be planing, anyway.) This will produce a pile of long curled shavings the width of the edge of the plank. Then take a dowel a little thicker than the diameter of your mast and smoothly cover it with tinfoil or plastic wrap that wood glue won't stick to. Then wrap the dowel with a piece of copy paper held tightly against the dowel with rubber bands wrapped around the paper and the dowel. Now, take a curled shaving and, without breaking it (depending on the wood species, you may want to soak the shavings in warm water for a half hour or so to soften them.) brush PVA glue on one side of the shaving and wrap it tightly in the direction of the curl to a thickness a smidgen thicker to what you want to represent a scale mast hoop (to allow for a bit of "clean up" sanding later.) You should do it with a single shaving which would require a four- to six-inch shaving. Then secure the wrapped shaving with a rubber band around it. Do this for as many mast bands as you'll need, plus a couple for "insurance." Given the narrowness of a scale mast hoop, you can get more than one mast hoop from a shaving that's an inch or more wide, but you'll want to make more in case you break a few. Allow the rings to dry well on the dowel overnight. When dry, sand the outside of the glued-up shavings so they are fair and round, which shouldn't take much. Then you cut the mast hoops on the dowel. If you have a lathe, this is a piece of cake. You just mount the dowel and as it turns you lay a sharp knife or fine saw on the dowel and cut straight down the depth of the glued-up shaving. If you don't have a lathe, you can chuck the dowel in a drill motor and put the drill motor in a vise or whatever and cut the rings as it turns, or, if you must, just roll the dowel and cut the hoops that way, but you have to cut straight and not create a spiral cut! Once the rings are cut to the width of your mast hoops, slide them off the dowel without breaking them. (They'll be surprisingly strong once they are laminated up with the PVA adhesive.) The hoops will be stuck to the paper somewhat, but not to worry. Simply put the dowel in water (but be sure the PVA is dry.) and the paper will soften when it gets wet. When the hoops come off, clean them up on the inside by scraping with a hobby knife or a bit of sandpaper and sand the edges to "soften" them a bit so they look good. They can then be stained and shellacked, or not, as you think looks best. (Mast hoops aren't commonly painted.) These mast hoops can then be attached to the sail with a stitch over the bolt rope as in actual practice. This method is actually easier to do than it is to describe in words and, in my opinion, produces a killer effect on a model.
Don't feel too frustrated that the kit's instructions and plans don't correspond exactly with the "parts." Back in the day, a "kit" was just some plan drawings, a rough carved hull block, and a bundle of sticks and dowels. Sometimes, if you got any sheet stock, they might have printed the parts on it for you to cut out, but that was it. Now, many modelers, particularly those who were used to cutting plastic parts off sprues and everything fit together perfectly, are surprised that wooden kit building requires cutting and shaping parts to fit, but that's how it has to be done if one is going to make a good model like you're doing.
Keep up the good work!
It certainly was! Thanks for all the words of wisdom. I'm not sure I'm up to making my own mast hoops (yet), but with my next project (which I plan to be a real ship, the Model Shipways Harriet Lane) I will strive for more historical and scale accuracy. I think of these 3 Model Shipway kits as tools for learning basic modeling techniqures that happen to produce a nice looking display piece.
The inaccurate instructions drive me crazy partly because it would be so easy to correct, and partly because my being-a-doctor-related obsessive tendencies make me want to do things by the book (12 years of Catholic school education with nuns doesn't help - I do what I'm told!).
Post 11 - A Quick Update and some Newbie Questions
I finished manufacturing the spars today. Model Expo neglected to include the proper number of brass eyelets, but it was easy enough to make my own from the stems I clipped off the eyelets to get them to fit in the spars. I used the smallest diameter of my jeweler's pliers.
I made the one in the jaws.
My questions:
I'm about to start stropping the blocks. I don't like the supplied copper wire - it's too big and they should be stropped with rope. What would be the appropriate diameter scale rope to strop 1:24 scale blocks? The supplied blocks are 7 mm (probably shaped down to between 5-6 mm). I have 5 mm blocks from Syren that I plan to use. How about the gauge of wire to make the hooks? I also understand that a ship of this period probably had internally stropped blocks. I'm thinking of buying them from Syren Ship Models as an experiment. They come in 1/8, 3/16 and 1/4 inch sizes. Which would be in scale? Chat GPT tells me smacks had 5 or 6 inch blocks for the halyards, and a larger block for the traveler, so I'm thinking 3/16" blocks and 1/4" for the traveler if I go that route.
I also plan to add parrels. I know to use seed beads (the instructions show black, I think) but what is the appropriate size? I am thinking 2 or 3 mm. Any input from the collected wisdom of the foum would be appreciated.
You’re doing a great job!
By the late 1800’s when this boat would have been built, internally stropped blocks were used. The sheave rotated in a fork shaped iron or steel frame and the line was spliced to this frame too. A pair of wooden cheeks covered each side. These cheeks were not grooved. The blocks were often painted.
Roger
Tell me about it! I had 16 years of the same, and Jesuits, to boot! (I've got the ruler-scarred knuckles to show for it. :rolleyes:) That was followed by nearly fifty years of trial and appellate law practice in which everything I wrote had to be thoroughly researched and backed up with citations to authority, which really turned me into a pedantic pain in the ass to those for whose highest standard was "close enough for government work!" ;) The problem you're describing isn't caused by wanting to do things by the book. The problem is caused by an inherent defect in the book you're following. Unfortunately, failing to correct that which should easily be corrected is a characteristic of many, if not most, ship model kit packages to one degree or another. This is antithetical to high-quality scale ship modeling as a fine art, of course, but the model ship kit industry is profit-driven and, while capitalism isn't necessarily a bad thing, when profit and art are concurrent objectives, both cannot occupy the same space at the same time and it's art that always gets the hind teat. There are those modelers who find satisfaction alone in assembling kits and some do it very well, although in the case of most kits, in order to do them very well, one must virtually throw "the book" out and build from scratch to achieve the level of craftsmanship and accuracy to which the modeler's skill and experience are capable. Simply put, anybody who can do a high-quality ship model from a kit almost certainly has a skill level well above that which the kit manufacturer contemplated when designing their product.
As Roger pointed out with far more grace than I ever could, there's more to be "easily corrected" in your kit than you've already discovered on your own. It's just such attention to detail which distinguishes the high-quality scale ship model from other ship models, however attractive to the inexperienced eye the others may be. I'll mention in passing that it was expressing such observations that caused the kit manufacturers who control the MSW forum and have a vested interest in keeping novice modelers building kit after kit as if that were all there was to ship modeling which got those of us in SoS who adhere to recognized standards of quality "banned" from the kit manufacturers' MSW forum!
"A high-quality scale ship model provides a compelling impression of an actual vessel within the constraints of historical accuracy."
"Historical accuracy" encompasses all the objective, or measurable, standards of technical exactness that might apply to a ship model. These embrace the obvious hull shape and fairness; precision in fittings, rigging, and colors; lack of anachronisms; and so forth. But it also encompasses all aspects of craftsmanship because the lack of craftsmanship creates unrealistic and, therefore, historically inaccurate blemishes on a model. ... The phrase "historically accurate" alone effectively replaces the intention of the now-vapid "museum quality."
"... (A "compelling impression") allows and encourages aesthetic interpretation of a vessel that will help propel the viewers to make the leap of faith that allows a model to work or to willingly suspend the disbelief that keeps a model from working. Both processes help viewers accept the invitation to visit a ship instead of a model. Compelling impression is the result of applying artistic and interpretive decision-making processes... to amplify a model beyond being a mere assemblage of parts.
Rob Napier, Caring for Ship Models - A Narrative of Thought and Application, (2022) Seawatch Books.
See: https://seawatchbooks.com/products/...tive-of-thought-and-application-by-rob-napier
I realize that for many modelers, kit modeling is an end in itself, and they don't seem to mind that the upper limits of their accomplishments may be limited by their kits' manufacturers. If they enjoy modeling, that's always a good thing. But I also know some become very defensive when any mention of objective standards of quality are mentioned. Many "see red" when comparisons between ship model kits and "paint-by-number" painting sets are mentioned. Others will assert a "right" to build their models to whatever subjective standard they please. I won't knock people who strive for self-defined perfection in making their kits, though, because that is certainly a challenging enterprise in any event. I've seen some admirably high-quality kit-builds, but, I'm just saying that, in my opinion, such accomplishments rank right up there with the proverbial "rich man's getting into heaven." Since you are a medical doctor, I'll offer a simile from your own profession and say that a modeler who builds kits is a lot like a doctor who relies upon Artificial Intelligence for their diagnostic impressions. (Although, not being a doctor, I have no idea if that reference might raise the ire of doctors as much as the former does the ire of some kit modelers! :D)
It is obvious from your build log that you have the basic skills and attention to detail required to be a very accomplished scratch builder. There is a natural progression in naturally predisposed accomplished ship modelers from building a kit or two, through "kit bashing" a kit or two to raise to the level of their own higher standards, to, finally, pure scratch-building free of any dependence upon prepackaged kits. The sooner one gets to the end of that evolution, the better off they'll be, so I'm just taking this opportunity to give you a bit of a nudge in that direction. Don't hesitate to use your current build to accelerate your evolution to independent high-quality scale ship modeling. If you do that now, you will be that much far ahead when you get to your Joe Lane build. The more you learn from the model you're building now, the more you'll know when you build your next one.
As for adding to the skill and experience you already have, you will find the School for Model Ship Building section of this forum a treasure trove of basic information specific to ship modeling. Read and learn. You should also start building a library of basic ship modeling reference books. Use this forum's search engine to find recommendations. (Anything by Davis, Chapelle, or Underhill will stand you in good stead for openers.) Once you have a good grasp of reading naval architectural drawings, you'll be able to build anything from the literally thousands of plans available in public records and books, without buying a kit.
Luckily, I retired from Medical Oncology two years ago, before AI had any influence on my practice! Got out just in time.
I have the goal of building scratch built models (my plan for the first would be a Wianno Senior, the type of day sailer my in-laws raced in Hyannis Port, and the only wooden boat I have ever sailed), but I like building kits. Putting pieces together and following instructions appeals to me, which is why I also build Lego sets - order out of chaos. Not art, but at least craft. I have been slowly doing more "kit bashing" as I progress, and may eventually become frustrated by the constraints of a kit, but I enjoy it for now. I've had more fun in the last 9 months building these Model Shipways kits than I have had in a long time. I learn something new almost every day, and continuously amaze myself at what I can accomplish.
I am educating myself as I go along. Here's a picture of my small, but growing library. I'm awaiting a treasure trove of new old books I just bought on Ebay.
I tend to be compulsive :)
Nice work! As you've seen, I've been experimenting with ways to do internally-stropped blocks and trying to work out the block sizes and rigging diameters on this boat type.
I have 24 and 28 gauge wire, and have found that those two sizes are pretty useful, although a greater variety would of course be helpful. Annealed steel wire comes in a dark metallic color, which is great--when I was making my Lancha Chilota, I only was able to get annealed steel wire at the end, so most of my hooks were made of copper wire and had to be painted, which is rather annoying and required frequent touch-ups after handling. If I remember correctly (the buils log was lost), I used 24 gauge wire for those hooks, and they seemed to fit nicely alongside the 4mm and 5mm blocks I used. It took a few tries to get the hooks right, I can't remember whether I did the bends around my jeweler's pliers, or around sewing needles of different thicknesses. I will probably try the latter method as I move into rigging my build as it seems more precise (my jeweler's pliers are cheap and uneven). For the size, I think that a bit undersized is probably better than oversized, if you can swing it. I'd recommend checking out photos to get a sense of proportions. These two photos (links here and here) are fairly high-quality.
For the parrels, looking around at photos online, it looks like 4-7 or so beads would be reasonable.
Yes, the copper wire is way over-scale for what you want. Get some pictures and do the math yourself. Google is our friend. Go to your local "bead store" or any craft store that sells beads. You should find copper wire in a variety of sizes, or strip scrap copper wire and use that. You can make your own blocks easily enough. Here again, use the SoS search engine. I'm sure there's a block making tutorial in here somewhere. You only have to make a half dozen or so. It's not like you're building a First-Rate ship of the line.
The size of the line dictates the size of the sheave, and the size of the sheave dictates the size of the block cheeks. You will have to determine from your own research whether the block sizes that are being referenced are the diameter of the sheave or the overall height of the block shell. There's a big difference. Do some research. There are tables for use in determining the size of line and blocks if you want to get technical. A wild guess would be that your sloop would be rigged with no larger than 5/8" or 1/2" diameter running rigging cordage and that would mean about a 4" or 5" high block shell. (Note that in earlier references, particularly British naval material, the cordage sizes are given in terms of circumference.) If your scale is 1:24, a half-inch equals a foot. six inches would equal a quarter-inch, so "ballparking it," I'd guess a 3/16" tall block shell would be about right. I wouldn't go over a quarter-inch though. However, "If it looks right, it is right." provided that you know what you're looking at. You can do the math if you have the schedules or you can "eyeball it" to determine the proper size of the wire you are going to use.
Making metal stropped blocks is easier than making rope stropped blocks by a wide margin. Just drill two holes in the top of the block and insert a properly sized "U-shaped" piece of wire into the holes with a bit of adhesive and you're in business. For a bail on the bottom of a block, you can place a single eyebolt if you want. If you want to get fancy, and at 1:24 scale, you certainly can, you can make shackles to fasten the blocks to eyebolts were necessary. To make shackles in 1:24 scale, take some "telephone wire" (as described in my earlier post above) and cut off a length suitable to make a "U-shaped" shackle (or a rounded one, if that's what you want.) Before you bend it to form the shackle, take a flat faced punch and a heavy hammer and place the wire on an anvil and the punch over a shore length of each end of the length of wire and give each end a good whack with the hammer so that the flat punch face (or whatever you're using to mash the end of the wire) mashes the ends of the wire flat, forming a flared shape. Drill a hole one size larger than the diameter of the wire in the center of each flared wire end. File the flared ends with the holes in the middle to a rounded shape as the ends of a shackle. Bend the wire with the rounded flat ends with the holes drilled in the center of each into a "U-shape" to form the shackle. Take another length of the same copper wire and smash one end of that and file the squashed spread end into a rounded shape to form the pin of the shackle. To assemble the shackle, place it as a real shackle would be to hang the block and run the pin through the holes in the shackle. Fasten the pin with a drop of shellac or CA. Trim the surplus end of the shackle pin off flush with the shackle hole.
Note: metal "coins" (actual coins are sometimes used) with two screws on the edges are used to secure the sheave axle in place. Note: the size of the eyebolt on the deck next to the block. The eye of the eyebolt should be not much larger in diameter than the diameter of the "ring" and "post" of the eyebolt.
Note: shackles below.
Note, poor seamanship! The line through the strop will chafe through and break in relatively short order. The line should be spliced around a metal thimble and the thimble shackled to the block to prevent the line from chafing through.
Note: Rounded bails, flattened out where they enter between the cheeks.
Note: Over-scale eye and hook on rope-stropped model block. Throat seizing too wide.
Note: Full-size rope-stopped block with thimble and hook. (Throat seizing missing.)
I've never seen black parrels on a boat, although I can't think of any reason why not, except that wood which is intended to wear on a boat isn't painted. Oiled or tarred sometimes, but never panted. Usually left bare. The paint would just wear off. I've seen round parrels on some smaller boats, but parrels on larger boats from about the size of your sloop and upwards often use parrels which are "drum-shaped," more "rollers" than "beads." This is probably because it's a lot easier to make the "drums" than to turn the "balls." The parrel will be about six times the diameter of the cord used to string them. In this case, I'd figure the prototype would have about a 1/4" parrel cord, so the parrels would be around an inch and a half or a bit less in diameter, which at 1:24 scale will be around 1/16" in diameter. Wooden or at least "bare wood colored" beads or some sort of seed... or just forget the parrels entirely. They wouldn't be much more than window dressing on a boat that small. The boom jaws will generally be bearing against the aft side of the mast when full. Here again, "If they look right, they are right."
I'd never heard of it before, but the Wianno Senior is quite the sharp-looking boat! It looks like a great first scratch build.
I have to say, I've found scratch-building and kit-building both to be very rewarding. Rather than switch from one to the other, I've usually done both at the same time. (Actually, the second model I started, and the first I finished, was a scratch build.)
On one hand, I enjoy the research aspects of modeling, and have found it exciting to learn new techniques and really think through the build from scratch. I also don't think that scratch building necessarily has to be as complex as it may seem, it really depends on what subject you pick (and how many resources about it are available). The biggest advantage of scratch-building, of course, is that you have a lot of freedom to choose a subject that's meaningful or particularly interesting to you. I've found the Latin American workboats I've built, especially, which required a lot of research, to be both good learning experiences and very rewarding builds, and there certainly aren't any kits available for them.
On the other hand, sometimes it's nice to not have to make everything from scratch or to have to do research for every part of a build. Finding good modeling wood where I live in Mexico City is very difficult, I don't have access to the tools to really mill larger lumber to useful sizes, and with a limited workspace and tools at home, a lot of larger modeling tasks like cutting out frames or bulkheads have to be done in a carpentry workshop, which is nice to have access to but less convenient than a home workshop. Assuming the underlying structure of a kit is decent, having laser-cut bulkheads and the like can be a great time-saver to get into the more exciting parts of the build. My job involves a lot of research, so sometimes I'm a bit burned out on the research aspect and really just want to make sawdust. And of course there are plenty of ways to kitbash a model to make it more accurate and/or personalized. I'm finding my current Muscongus Bay Sloop build to be extremely rewarding, although it's from a kit.
Obviously, a lot depends on the kit in question. There are certainly many that are wildly inaccurate or really poorly designed, which would be frustrating, but there are some that seem better. The MS Emma C Berry kit , for instance, looks to build into a really nice representation, and I'm looking forward to building mine. The price is a serious issue, although I've had good luck at getting deals on Ebay. After finishing my current builds, I do want to do another Latin American workboat scratch-build, but I also have a couple kits on the shelf and may do one of them at the same time.
(Apologies for hijacking your post!)
An excellent start! I have them all except for the Boudroit "74 series." That's not a period I'm planning to be doing any building in and, while I wouldn't turn it down if the opportunity presented itself and the price was right, it is one of the most expensive sets of volumes in the ship modeling literary catalog.
I wouldn't say you were compulsive at all. A quick count comes up with an estimate of close to around two hundred feet of bookshelves packed solid worth of ship modeling, naval architecture, yachts and yachting, and maritime history, as well as numerous magazine copies and binders full of copied articles and hard copies of internet downloads (e.g.: a full set of WoodenBoat Magazine.) The proceeds of a lifetime of scrounging used bookstores anywhere close to salt air. There's "compulsive," and then there's pathological hoarding! :D
Not only that, but your fascinating series of indigenous small craft models represents an important contribution to the historical record as some, if not all of them are unique models of their types, quite possibly never modeled before and perhaps never to be modeled again.
Some Odds and Ends:
In rigging your model it’s sometimes a good idea to use under scale cordage and never a good idea for it to be overscale. As my friend Bob Cleek writes sometimes it’s what the eye thinks that it sees not what is actually there.
For making hooks I prefer brass wire to copper.
It’s my Engineer side but rather than the stepped jewelers pliers, I make simple dies; brads or wire in a block of wood held in a vise. I like Aluminum wire for dies as solder does not bond to it.
The blocks that Bob shows are “yacht quality”. Working boat blocks bought from the local ship chandler often did not have the nice rounded corners.
In 1990 as part of a job move I had the opportunity to have a house built to my specifications. It includes a separate room for my maritime history/ naval architecture library. There’s nothing compulsive about your book collection. As a physician with a firm scientific background I suspect that over time you’ll become interested in the why ships and boats are built the way that they are. We learn from Authors like Chapelle. I recommend his Boatbuilding book too.
Roger
Some Odds and Ends:
Roger
All excellent points.
If a hook is intended to actually take some tension, I agree that brass is the favored material although I find it often stiffer to work and trickier to blacken than I'd prefer. One additional point I'll add is that the wire I've seen provided in many kits is frequently over-sized. Also, in larger scales where it's a scale-appropriate detail, many modelers neglect to "mouse" their hooks which, prior to the invention of metal shackles, was an essential part of rigging a hook which was meant to remain in place for a while rather than be frequently cast off. This is particularly so with hooks employed aloft. A hook jumping out of an eye and permitting a heavy block propelled by the additional weight of often wet falls to plumet to the deck was a very serious safety risk.
For those who are unfamiliar with hooks and shackles and want to sharpen their nautical trivia skills:
Various methods of mousing hooks and shackles. Shackles are also moused, but generally too small a detail to include at most modeling scales.
Hook shapes: Slip hook is for thimbles, pad eyes, and ring bolts. Grab hook is for hooking over a chain link between two adjacent links. AKA: a "chain hook." Note the slight reverse bend at the point of the hook (quite minimal in the below illustration,) which can vary in degree as a matter of style. The reverse bend is important to prevent the mousing from slipping off the point of the hook.
Obviously, mousing is lashed on after the hook is attached to whatever it connects.
The way the hook is attached to whatever it's attached to is also very important.
The same goes for the way a shackle is loaded. Noter the difference between the "D shackle" and the "bow shackle." There's a reason for the difference in their shape. The former is for straight tension and the latter for divided side tension.
1779395766700.png'
The right way and the wrong way to place a shackle. Improper loading creates wear which can cause catastrophic failure.
I agree that if one is going to have to make a number of scale hooks, it is always preferable to devise a jig such as you've described to make them. This ensures uniformity. The jeweler's ring pliers are fine for uniform eyebolts (as is twisting around a drill bit shank,) but a jig is better for a lot of uniform hooks.
The wooden cheeked blocks I pictured are certainly "yacht quality." I had a devil of a time finding pictures online of "workboat quality" marine blocks. There were lots of pictures of what we used to call "farmers' blocks" with steel hardware, flat faces, and sharp corners (which are a danger aboard ship if one at the end of a flailing sheet, etc., lays up against your head!) The ferrous metal (not wrought iron) hardware on these blocks rusts up quickly in the marine environment, the sheaves freeze up, and they just fall apart. Workboat blocks will look much the same as "yachty" blocks, minus the varnished fancy wood species cheeks. "Farmers' blocks" are for hauling bales up to the hay loft, not for running rigging on a sailing vessel!
Library-wise, I'm in the process of doing the same as you've done. I'm converting a large 18' x 22' room above my garage into a library consolidating all the bookcases I've got spread all over the house. I kept the bookcases from my law offices when I retired and those are going in there. I was getting a bit of push-back from the missus about the three- and four-foot-high stacks of large modeling books stashed here and there around the house. I negotiated exclusive use and possession of the family room above the garage in return for a promise that I'd remove all my books from the rest of the house. ;)
I had a bit of an "Aha Moment" about the blocks for my Lobster Smack model. My in-laws raced a Wianno Senior, a 25 ft, gaffe-rigged sloop, about the same proportions as the smack. She was built in 1914, and had wooden blocks. Had a big mainsail, 294 sq ft according to the Wianno Senior Association design rules. We sailed her until 1996. The mainsheet and halyard blocks were 4 inches long. Jib halyard blocks were smaller. The design rules indicate that the throat and peak halyards can be no smaller than 3/8" and the jib halyard no smaller than 5/16," determined by their breaking strength. Sheets can be of any size. As the Smack and the Senior are similarly sized gaffe-rigged boats of a fairly similar vintage, it gives me a real-world example to base my blocks on. Calculations indicate that 4 mm blocks with 0.4 or o.5 mm line for the throat and peak halyards, and 0.3 mm line for the jib halyard should be fairly accurate. I could make the main sheet a little larger, 0.5 mm. I've attached a few pictures of the Mimi, from the 1960s.
Great work. I built the Midwest Lobster Smack kit which is slightly different but follows the same general look. I did not like the copper wire for the blocks either, so I followed Olha Batchvarov's use of varying sized polyester threads. Here is the video where she is showing the technique of using heavy thread with lighter weight seizing. The detail starts around 1:21 on this YouTube video:
. They are much more elegant and feel visually accurate but I had a hard time understanding the exact size thread - so I guessed. Good luck with your build!
Indeed you did! And you are 100% correct. You've just demonstrated why why practical knowledge is so invaluable to successful scale ship modeling. Without practical seamanship experience, preferably a lifetime "simply messing about in boats," as Ratty the Water Rat put it, scale ship modeling is a very difficult pursuit, try as kit manufacturers might to convince their customers that "anybody can do it." It's a lot like becoming fluent in a foreign language. It's a lot easier to master a foreign tongue by "total immersion" than from a grammar textbook. If you know what it looks like, you can rely on the maxim, "If it looks right, it is right." but if you don't know what "right" looks like, you're pretty much SOL. ;)
