Le Fleuron 1729 scale 1/75 - Boudriot & Delacroix
Slowly but surely the deck equipment is coming to an end. The last deck that I was missing was the Gangway and its stairs.
For me, soldering is probably the hardest thing. I'll probably never learn it, but I'm glad I managed to do it this way.
Well, here are the last two stairs (ladders) to the top deck.
Since I had all the decks finished, I started installing the interior railings. First, I glued the previously made front railing, including the large bell.
Potom stredné zábradlie s malým zvonom.
And finally, the last one at the back. That was probably the hardest for me. My imagination had to play a little, because my skill failed. The carved decorations are my invention and I strayed quite far from the original. I am convinced that there are people who can do it, but I am not one of them. But on the other hand, I am glad that it turned out this way.
Just for comparison with a ruler.
Then a middle railing with a small bell.
They look great! If you can get this detail at 1/75, I'm going to try and do as well on my current 1/48 build.
Inspiring. Thanks for sharing!
Thank you, Brad. I am sure you can handle it with no trouble.
I'm delighted to see the detail you get at this scale. Bravo!
Thanks, dockattner. I think we're in the same boat. Your skill is impressive.
I finally forced myself to finish the second bouquet, which complements the back decoration by the lantern.
I don't really like repetitive work, I prefer to always do something new.
Here is a small overview of the work on the bouquet.
And here is the result
And now, I have thrown myself into decorating the side of the balcony. I wonder when I will get around to doing round two on the other side
Just to give you an idea of the dimensions.
Today I will add only two photos. I continue with carving the decoration on the balcony. I don't miss much and I will have the entire mirror finished.
I had a pretty serious incident with the winged coat of arms. I laugh now, but before that I was about to cry.
I wanted to polish the finished coat of arms before sticking it on the balcony. When I approached the coat of arms with the spinning felt disc, it flew out of my fingers at such a tremendous speed straight into the wall that I almost lost my breath. I work in a 1.6 x 1.6 meter room and for a good 30 minutes I couldn't find the coat of arms. I was really about to cry. A whole 6 hours of work was wasted.
But then a miracle happened and I found the coat of arms undamaged.
You are lucky the "carpet gremlins" didn't take your wonderful coat of arms and furnish their hidden home! I've lost a few to these "gremlins". It seems they tire of them after a few weeks or months and then return them to the workbench in some unexpected place...
I am in awe of your stern decorations. Such detail!! Much admiration for your patience and skill.
Thanks for sharing!
Witaj
Więc to prawda cuda się zdarzają . Pięknie rzeźbisz masz dar więc korzystaj ,piękna praca pozdrawiam Mirek
