USS Constitution - Model Shipways
They look great Peter,
Sorry to have added to your wood turning woes, but eternally grateful
I turned a 4mm ish (5/32") dowel for the spanker mast, fabricated the boom rest, and test fitted all to the lower mizzen mast.
The plans call for there to be a square tenon at the top of the spanker mast. SInce I wasn't sure where that end of the mast would meet the top of the trestle trees, I held off on cutting it, which may be a good thing, because I seem to be about a quarter inch short in relationship to where I think it's supposed to fit. I know where I will make my adjustments, once I learn exactly where that square tenon falls in the grand scheme of things.
For now? An adult beverage and game one of the Stanley Cup finals.
Hey, does anyone actually put the "clapper" on (or is it in?) the Spanker Gaff? Bob Hunt completely ignores it in Chapter 2, section 1.8, despite displaying it in picture p2.1.8-2 on page 45.
There's no reference to this in Anatomy of the Ship by Marquardt.
I have yet to find it mentioned in anyone else's build. Intimately I haven't checked every single Constitution build log here...
Obviously, I haven't installed it...yet. I didn't even know what it was, so I googled it. I found this on SuburbanShipModeler, a site I didn't know existed before.
On a traditional gaff-rigged sailboat, the "clapper" is a pivoting, flat wooden block situated in the throat between the "jaws" or forks of the gaff or boom. Its function is to provide a larger, smoother bearing surface against the mast as the spar tilts and slides. [1, 2]
The jaws cradle the mast and keep the spar connected, while the clapper pivots back and forth inside the jaws. It ensures consistent contact with the mast without binding, and is often covered in leather or "greased" with tallow to protect the mast's varnish from friction and wear. [1, 2, 3, 4]
This image is from the Bluenose build log on that site so it doesn't quite match up with the MS diagram (which I don't understand), but it does explain its function...if that helps.
Wait, I found an image from the Constitution herself:
And Gregg found a reference from Ken at the other website.
Taking both pieces in, I don't think it's worth the effort to produce, since it will basically disappear upon install. Evidently Bob Hunt felt the same. Here's how he describes the installation of the gas in his last chapter - the one without any photos of the Constitution.
So, I'll ponder the matter for a few days, probably forgetting it between now and the time I get to rigging.
Having said that, the spanker gaff assembly, minus the clapper, is complete.
The sheave is there..
Oh yeah! I did one of those on my Bluenose! I thought Ken's picture looked vaguely familiar! <shrug> The Suburban Ship Modeler site was an awesome lifesaver when I was working on the Bluenose. Great help!
One more piece turned. This is the spritsail yard.
I photographed it next to the existing Phase 1 of the bowsprit. And the blank of boxwood I might replace that bowsprit piece with. I can't decide if there's enough difference in the color to justify it, especially since a good part of this will be buried in the hull, and some of it will be covered with steps, jib boom saddle, bees, and what not.
There will be a color contrast, in that I'll be making the jib boom out of sapelle, (then back to boxwood for the flying jib boom). The only nearby wood to compare it to would be the steps, which I plan to make out of boxwood.
hello,
Would you happen to know if the lower masts are tapered? The plans I have do not show a taper, yet when I research on internet, it says that they were.
The MS kit plans are not the best, Jack. Other resources for information are likewise deficient and oft times contradictory. Thank God for the likes of Mustafa, (Jon and Ken, apologies to anyone I'm overlooking), who are always ready with answers to questions like these.
where i got confused is that I used the plans to measure the diameter of the lower masts and I didn't see that they had the taper diameters already on the plans. But even at that it would have been nice if they had shown more taper diameters as you go up the lower masts.
