- May 25, 2020
Martin! This is great stuff my friend! Thank you! Short answer is maybe not.first question , while on the subject of reinforcements, will you be fitting Jumelles? mast hounds ?(wooden battens that support the mast at the point of movement of the yard )These are fitted after the mastbands (which i now have info at width, 1/7 thickness of the mast at a distance of "3 pieds à 3 pieds et demi" so you are about right at 1metre) but then attached with rustures (wooldings) , their height should be equal to between 3/7 and 1/2 the open mast height.? i'll find some photo's
Blessings. Peace. Gratitude.
Chuck
, not really with it ! here's a bunch of busy frenchmen attaching a Jumelle to the mast, it is really to protect it when raisng and lowering the yards and is disposable. the second photo shows a shorter version from 1740 but they gradually got longer until almost reaching the deck, not fitted to the mizzen mast
if you have any other queries i will see what i can find.
