I've made a few mistakes, and I suppose I'll continue to make themHi Bill,
I’m under no illusions that this will be my first and last mistake (I’m actually going to keep count of them!
Luckily, looking around the forum, I can see that I’m not the only one—and neither are you!
Greetz, Peter
¡Hola Lorenzo! ¡Muchas gracias! ¡Mi primer error fue de lo más innecesario y tonto! Qué bien que tú, como experto experimentado, sigas mi hilo de construcción (y me dejes tus comentarios).I've made a few mistakes, and I suppose I'll continue to make them. You're going to have a good time building it. I'll be following your progress closely.
Support beams are a great idea .Placed all the bulkheads today.
Already made my first mistake; I had already mounted the last bulkhead, which meant I couldn't place the support beams anymore.
I thought I could manage it all without the manual (RTFM!) After some painstaking demolition work with a Stanley knife, the beams could be placed. Finally, remounted the last bulkhead.
Haha, thank you, but all credits go to Occre; it came with the kit.Support beams are a great idea .
Hi Tom, thank you; that is an excellent advice.If your using wood glue or white glue, just paint isopropyl alcohol over the joint. You need to keep doing it to keep it "wet" and gently wiggle the part every so often, but don't force it. It will eventually come loose. Takes about a minute. Let the alcohol evaporate then scrape the dried glue off the parts. You can also use water, but the isopropyl alcohol is more effective. The 90% is better than the 70%.
One of the main lessons I've learned is to not be afraid to unglue parts to fix a mistake. It's easy to do, and much better than trying to jury rig a work around.
Thank you, Peter.A bit late visiting your log, Peter. I also started with a big 3-masts ships as 1st model. ‘RTFM’ is not old fashion and not bad at all. Every manufacturer has it’s ‘special approach’. Your 1st re-do is not in view at the end. Wish you a lot of fun with this build and will follow it.
Beep,beeping, beep- looking good in R2D2 speak….Past week, I was largely tied up with HOA board duties, but today I managed to take a few modest steps forward again.
but right now I’m multitasking: updating the build log while keeping one eye on the Netherlands vs Sweden World Cup football match.
Decks are sanded and coated.
The walls have been installed, but the front wall doesn't fit perfectly flush with the deck. I'll fix that by adding a baseboard.
Slowly working my way towards installing the bulwarks.
