"Smalschip" 17th-century Dutch inland cargo ship from plans by Ab Hoving - Build Log
Bryn Mawr PA US
1. Build Log - "Smalschip" 17th-century Dutch inland cargo ship 1/48 scale, in paper cardstock from plans by Ab Hoving in his book "Dutch 17th Century Ship Models in Paper: An Introduction to Scratch Building Paper Ship Models," from SeaWatch Books.
I started this build because I wanted to learn the Ab Hoving method of building scale ship models in paper and cardstock. Mr. Hoving has been very helpful to me (and many others on SoS) in my pursuit of building 17th-century Dutch vessels, like the Jaght Heemskerck, the Kalmar Nyckel, and the Statenjaght Utrecht.
He has also been generous with his time and with his sharing of his ship designs and tips on his building method. His book about Dutch ship models in paper is beautiful (thanks to Emiel Hoving's book design and graphics), enlightening about 16th and 17th century Dutch ship building practices, and the book makes a great case for using paper and cardstock to build ship models in scale. As Ab Hoving has said on this forum when speaking about his paper cardstock building method, "It's so easy." I totally agree.
All my previous attempts at building model paper kits (mostly from Eastern Europe) came up short because I found that any mistaken fold, incorrectly glued fold, or mis-cut paper parts could rarely be fixed and the traditional paper builds were very frustrating. I started and did not complete paper models of the Graf Goetzen armed cargo ship, the Centaur ocean tugboat, and the Cyclon II tugboat. I vowed not to go back to paper building until I heard of the "Ab Hoving Method" of building in paper and cardstock.
Once I saw how beautiful Ab's models were and how apparently easy the method was, I dove right in and started building the 17th-century Dutch "Smalschip." The book also has plans for "Witsen's Pinas" another 17th century merchant/naval vessel.
Here is a picture from Ab's book of his model "Smalschip," a 60-foot long utility ship that could work far inland because it's 16-foot width could pass through standard locks that extend far into the Dutch provinces:
I do not want to go into too much detail about Mr. Hoving's build method, because people who are interested should read some of the build logs using the method and should purchase this book from SeaWatch Books. I will also only make sparing use of pictures from the book because I want to respect Mr. Hoving's copyrights.
As to this method of building, basically using enforced cardboard, chip board, and heavy paper cardstock, I'll just say:
1. This method of building is easy, forgiving of mistakes, and if you messed up a part or component, you just have to take 5 minutes to fabricate another one.
2. The method does not require any special tools, adhesives, or substrate materials. Everything you need (except maybe EVA foam) is probably already in your shop.
3. The method allows for an incredible amount of creativity and modeler's choice - If you want to build a vessel from Amsterdam, research and use the flag of Amsterdam, you just have to fabricate the flag and paint it yourself. You can depart from the drawings and still have a good build...you are only limited by your imagination.
4. Since there is a minimal investment to get into this build method, if you don't like the outcome, just build another one.
5. The method lends itself to scratch building from plans, especially in the 1/48 and 1/96 scales.
6. Because most structural components in paper or cardstock can be soaked or impregnated with glue (CA or PVA) to make them strong (use CA) or flexible (use Elmer's glue). Cardboard soaked in CA glue is as hard as wood and can be sanded, cut and painted.
As for materials, here is what I used in building my Smalschip:
1. Paper stock in 20 lb., 65 lb., 80 lb. and 110 lb. & plastic foam (I use EVA foam because it keeps its shape when painted).
2. Adhesives
3. Cutting tools (shears cut cardboard very easily).
4. Cardboard, chip board, Foamcore, or hardcover book covers, in 1mm, 2mm and 2.5 mm. When needed, the paper cardstock can be combined to thicknesses of 4 mm to 8 mm. Above 8 mm and you may want to use balsa wood.
1000021863.jpg -
5. Plans -- Here are some of Ab Hoving's design drawings from the book.
I am now almost done with my Smalschip build, but I want to spend a few build log entries showing my step-by-step build process using the Ab Hoving method.
Here are a few pics of where I am now. I am building my Smalschip before 1700 when the Prinzenvlag (House of Orange) would have been used. She is also sailing out of Amsterdam, so she flies the flag of Amsterdam. I just have to finish the skeleton rigging and add some scale figurines and then I should be done.
2. Build Log - "Smalschip" 17th-century Dutch inland cargo ship 1/48 scale, in paper cardstock from plans by Ab Hoving.
Building Hoving's "Smalschip" from scratch, here are some early build pictures.
The build begins as a typical plank-on-frame model with bulkheads, keel and rabbet. The bulkheads are fabricated out of 2mm cardboard. The keel and planking slots are also 2mm cardboard, but supplemented by a 1-2 mm keel frame.
Ab Hoving's method gives the builder the liberty to frame the hull as a plank-on-frame build, as a sold-hull build, or any other way you choose. I started out trying to build as plank-on-frame, but since it was my first time in this build method I had trouble keeping the frames in alignment. So after a few tries at plank-on-frame, I decided to build the hull as a solid hull. Again, so easy to make this transition to paper building once you get used to using cardboard instead of wood.
Next, putting the hull together as a solid-hull.
Once I had my solid hull together, I spent time fairing the raw hull to ensure that the top deck reflects the cambered deck from port to starboard, and the saddleback deck from stem to stern. It took a couple of times to get both cambers right, but it is needed so the decking material can lay flat atop decks.
Ab Hoving's ship design includes a double-planked hull. So I had to test different strengths of paper cardstock to find the right stock to use for both the under layer of planking, and then thinner paper cardstock for the outer layer of planking.
I did alot of trial and error to find the right paper stock and the right planking diagram to create proper sized outer planks. I used a planking diagram from another model kit and just copied it onto paper cardstock. I ended up using 110 lb. paper stock for the inner planking and a 65 lb. paper stock for the outer planking.
Top wales and keel support are cut from legal file folders, which usually have a perfect 1.5 mm thickness. If you use this method, you will always need to think, "how thick must this component be in order for it to be stable, to fit with other members, and to stay rigid. I infused diluted Elmer's glue and CA glue into some bulkheads to add stability to the build.
Once the planking is complete (I redid the outer planking 4 or 5 times to find the correct width of the planks for a 1/48 scale model), next step is to build the upper, middle, and lower wales in strips of foam. I am using EVA foams because it keeps it's form even when painted.
3. Build Log - "Smalschip" 17th-century Dutch inland cargo ship 1/48 scale, in paper cardstock from plans by Ab Hoving.
At this point in the build, I am experimenting with different materials, different thicknesses of card paperstock, and different adhesives. Each step seems so rational and sensible -- finding ways to solve problems and using common sense to make a beautiful model. After planking, I am focusing on the deck furnishings (windlass, horses, hatches, main hatch, cabin, bilge pumps, and leeboard). Then focusing on shoring up the keel, stempost and sternpost, with additional 1.5 mm layers of legal file cardboard.
The leeboards gave me a bit of a problem because I kept going back and forth between fabricating them from card stock or using 1-2mm bass wood for a grained look. In the end, I decided to build the leeboards from 3 sheets of 1 mm card stock washed with diluted Elmer's glue for strength.
Mr. Hoving advises that all scale models should be populated with scale human figures to show off the dimensions of the ship and to give it a realistic look and feel. In his book he writes, "One of the advantages of adding figures is that the scale of the model suddenly becomes clear to the viewer, The human size works as a reference." "17th Century Dutch Ship Models," page 51.
It took a while to find miniature human figures in 1/48 or 1/50 scale. I tried different figures in 1/64, 1/50, 1/48 and 1/32 scales and am still waiting on another set of figurines in 1/48.
4. Build Log - "Smalschip" 17th-century Dutch inland cargo ship 1/48 scale, in paper cardstock from plans by Ab Hoving.
Not going to say much here. Just putting out pictures from the vast middle part of this build, in between planking and rigging.
And at this point, I started to think about what flags I would like to use. I did my research into the history of the flags of the Netherlands. If this ship were operating before 1765, it would have flown either the orange/white/blue flag of the Princes of Orange (the "Prinzenvlag") or the flag of the Seven Provinces, which would become a republic around 1800 (the red/white/blue "Statenvlag"). Another option is the complete orange standard of the House of Orange. I also wanted to represent her as allied with a particular province or city, so I chose to fly the flag of Amsterdam at the stern. I do like that the color orange is associated deeply in the hearts of Nederlanders, so I went with the Prinzenvlag and the triple-X flag of Amsterdam. I fabricated the Amsterdam flag using water-slide decals on 65 lb. cardstock. I fabricated the Prinzenvlag, Statenvlag, and Orange standard using 80 lb. cardstock and orange and blue painters' tape.
5. Build Log - "Smalschip" 17th-century Dutch inland cargo ship 1/48 scale, in paper cardstock from plans by Ab Hoving.
An interlude about the Dutch Smalschip.
The story of the 17th century Dutch Smalschip:
The smalschip ("narrow ship") was one of the most important working vessels of the Dutch Golden Age. Developed during the seventeenth century, it was designed specifically for the Netherlands' extensive network of canals, rivers, and inland waterways. The vessel's defining characteristic was its narrow beam, which allowed it to pass through restricted locks such as the important lock at Gouda. Contemporary descriptions indicate that the smalschip was closely related to the larger wijdschip ("wide ship"), but was built to narrower dimensions so it could reach inland markets inaccessible to larger craft. These vessels typically carried grain, peat, timber, bricks, agricultural products, and other bulk cargoes between Dutch towns and ports. Their shallow draft and relatively simple rig made them economical and well suited to the sheltered waters of the Dutch Republic.
Smalschips were a common sight in Dutch art and maritime records. The marine artist and seaman Reinier Nooms depicted smalschips in several engravings during the 1650s, showing how familiar these vessels were in everyday Dutch commerce. Surviving references suggest that the type was not associated with a single famous individual vessel in the way that large East Indiamen or warships were. Instead, the smalschip's importance came from the thousands of ordinary cargo voyages that supported Dutch trade and urban growth. Drawings and studies preserved by the Royal Museums Greenwich and the Rijksmuseum provide valuable visual evidence of the type.
Although no original seventeenth-century smalschip survives intact, several museum-quality reconstruction models have been produced. Maritime historian Ab Hoving and colleagues created digital and physical reconstructions based on the measurements published by shipbuilding author Nicolaes Witsen in 1671. These reconstructions have appeared in museum exhibitions, scholarly publications, and modern model kits, allowing visitors to examine the vessel's hull form and construction in detail. By the nineteenth century, the smalschip gradually disappeared as Dutch waterways were enlarged, canal infrastructure improved, and newer cargo vessels—including larger barges and mechanically powered craft—offered greater carrying capacity and efficiency. The smalschip's legacy, however, remains significant because it represents the practical inland transportation system that helped make the Dutch Republic one of the world's leading commercial powers.
Here are some Dutch paintings that include one or more Smalschips.
Here are some pictures of Smalschips:
And here is a new model kit from Noback Ship Models of the Smalschip based on Ab Hoving's designs in "17th Century Dutch Ship Models in Paper."
I must say, that I have been very impressed so far with the Ab Hoving method of building ships with paper cardstock. I look forward to building more scratch built ships designed by Ab Hoving, and I have the following Hoving-designed ships in my build queue:
1. "Witsen's Pinas" - 17th century Dutch pinas / pinnace merchant vessel / warship. From Mr. Hoving's plans in "17th Century Dutch Ships in Paper Modeling". Paper cardstock build.
2. "Jaght Heemskerck" - 17th century Dutch oorlog (war) jaght from Mr. Hoving's plans in "The Ships of Abel Tasman." Also considering building the "Fluyt Zeehaen," the companion ship to the Jaght Heemskerck under Abel Tasman; from plans from Mr. Hoving in "The Ships of Abel Tasman." Published by SeaWatch Books.
3. "Statenjaght Utrecht" - 17th century Dutch staten jaght as Admiralty-style / Navy board-style scratch wooden model from plans by Mr. Hoving in "The Statenjaght Utrecht" and "Scratch Building the Statenjaght Utrecht," by Gilbert McArdle. Published by SeaWatch Books. Scratch wooden build.
4. The "Onrust (Restless)" - Dutch speeljaght built by Adriaen Block in 1614 near Manhattan Island and 2009 museum ship re-build on the Connecticut River. Kit-bash from plans for the Jaght Leida by Corel and plans for the Jaght Hollanda. Scratch paper card build from plans.
The Onrust 1614 as 2009 replica ship.
Congratulations with your build!
Great ad too. ;)
Ab
Ab -- I know you have said that the 17th century Dutch loved to fly their flags...in my Smalschip build, would the combination of the Prinzenvlag and the 3X Amsterdam flag be realistic before 1765? I know you also said that the 17th century Dutch enjoyed flying BIG flags, is my Prinzenvlag atop the mainmast in reasonable proportion? I'm thinking that I might also change the Prinzenvlag to a banner or pennant instead. Thank you again for all your guidance and inspiration!
6. Build Log - "Smalschip" 17th-century Dutch inland cargo ship 1/48 scale, in paper cardstock from plans by Ab Hoving.
Rigging the Smalschip.,,
I had a couple of choices when it came to rigging the Smalschip. Ab Hoving's complete design plans have a fully rigged Smalschip with both a square mainsail and a gaff sail or jigger sail aft. He sews sails beautifully, but rigging is really one of my weak spots. My last fully rigged build, the Esmeralda, Chilean training ship had 19 sails 30 blocks and 4 staysails, damn near killed me!
So I also didn't want to leave a bare mast and boom, especially where the Dutch have turned rigging into an art form. But I don't think I need to get rigging skills out of this build. My main goal is to master the Ab Hoving paper cardstock building method.
I decided to do a "skeleton rigging" which is basically to attach every block that the vessel calls for, and run a standing rigging line through every block. I chose that route. I think a skeleton rigging can look realistic, give the ship some scale, and when the human figures are put back in the rigging will look in scale with the human figures.
So here are my rigging pics (more to come):
Well @Ignatius27, thanks again for promoting my book. I hope you inspired more people to give the method a try.
This is what it is all about: simply taking some easy to use materials and finding a way in building an attractive model. I never suggested the reader should follow the instructions in the book up to the letter, creativity is what is needed and what makes the build interesting. You clearly showed it!
By the way, in all modesty, the described method is in no way an 'Ab Hoving method'. Many builders used it before me and with much better results. I only described it in the book to inspire other builders and looking at this thread it seemed to have worked. I am sure that our book and threads such as yours will add to the accessibility of model shipbuilding in general, and even as an introduction to more complicated projects, like building with wood.
As for flags: I don't think a big flag like the one you put on top of the mast was much used in those days. What you may consider is to make a smaller one and add another one to the top of the sprit. Keep searching for 17th century pictures like painted by Willem van de Velde, Reinier Nooms, Ludolf Bakhuizen, de Vlieger, Abraham Storck and many others. There is a treasure trove of information in these paintings.
Good luck!
Ab
This is what it is all about: simply taking some easy to use material and find a way in building an attractive model. I never suggested the reader should follow the instructions in the book up to the letter, creativity is what is needed and what makes the build interesting. You clearly showed it!
Good luck!
Ab
Thanks Ab. I'm so glad you like my Smalschip. That means alot to me. I've tried to follow the method you describe as best I could. And as you say, the method is definitely designed for people (like me) who like to create and be creative in selecting and building modeling projects.
I am also going to use paper cardstock to model Witsen's pinas as an Admiralty-style or Navy-board presentation model when I build Witsen's pinas in a couple of weeks. And finally, thanks for the info on Dutch flags...I will take your advice and make the Prinzenvlag smaller and add a flag or pennant at the bow. I can use the 3rd flag to bring in the VOC and claim the Smalschip for the Dutch East India Company.
I am in your debt. I plan to purchase your book "Message in a Model" from SeaWatch Books. I have had my eyes on that book for a while. I also plan to purchase your model kit of the Smalschip from Noback Ship Models for a friend in my modeling club who is just getting into your work. My next step is to take the raw ship designs for a vessel like Tasman's Fluyt Zeehaen from your book "The Ships of Abel Tasman" and convert them into drawings that I can use to build a 1/48 scale cardstock model from. I will be seeing the Dutch/Swedish 17th century replica ship Kalmar Nyckel and the replica ship of The Half Moon in Boston for Sail250, the celebration of America's 250th birthday. Thank you!
You're welcome @Ignatius27 ,n no debts involved.
By the way, the publisher for the Tasman book is Verloren here in holland. https://verloren.nl/Webshop/Detail/...k5t2v8FPoJ09LDpIPlriB7W_aPXkX5mCthEu-iKvh2Bri. The book is still available.
Good luck!
Ab
Thanks Ab! My copy of "The Ships of Abel Tasman" from SeaWatch Books came last week. Verloren charged alot for shipping to the U.S., but that's okay. The CD-ROM is amazing. Do you have any tips for using the drawings for the Fluyt Zeehaen to create 1/48 paper cardstock plans that can be built using the paper cardstock method? I may just noodle around with the CD-ROM to unlock the treasures inside.
Yes, the cost of shipping is horrendous. The total costs for shipping the wijdschip book to Holland came up to 115 Euros (about $125). As a result I translated it into Dutch and made it available as an e-book for Dutch readers for a more appropriate price. https://nobackshipmodels.com/nl/books/models-in-paper/
I doubt if you will ever get the CD-Rom working. It was made even before Windows 95 and since long useless for newer Windows versions. Sorry. If you want I can mail you the drawings in digital shape.
As far as I can see the drawn frames in the body plan on sheet II will be sufficient to create a fair hull. I suppose you know my reports at SoS on the fluits I built.
Good luck,
Ab
Good luck,
Ab
Thanks Ab! I now have your drawings for the Fluit Zeehaen in the Abel Tasman book. My plan is to build the Zeehaen in paper and cardstock after I finish my wood build of the speeljaght Leida from plans by Corel.
8. Build Log - "Smalschip," 17th Century inland cargo ship from plans by Ab Hoving.
Flag day at the Ab Hoving Smalschip!
As with everything else, I experimented with different flags, pennants and colors. I researched 17th century Dutch flag traditions and laws. So in the end I raised 4 flags, from stern to stem:
1. Flag of the city of Amsterdam
Red field with 3 horizontal white crosses. The city or provincial flag always flies below the Prinzenvlag or the Statenvlag.
2. Pennant of the Dutch Republic (or the Statenvlag) in red, white and blue. The pennant came from a painting by Van de Velde the elder of a 17th century Dutch retourschip. The Statenvlag always flies above the city or provincial flag. The Statenvlag is ascending because it will supplant the Prinzenvlag above the mainmast by 1675 or so.
3. The Prinzenvlag (Prince Flag) of the House of Orange-Nassau (William of Orange, William II, and William III King of England and The Netherlands). Orange white and blue stripes. The Prinzenvlag would fly on top of the mainmast if used (before and after the Dutch Republic).
4. The flag of the VOC: Vereenigde Oostindische Compagnie (United East India Company). Usually printed over the red, white and blue Dutch tricolor...also over the Prinzenvlag. The world's first multinational corporation. The VOC was the backbone of the Dutch Golden Age in the 17th and 18th centuries. Many Dutch ships were used to protect the VOC, and the VOC lent many of their ships to the Dutch Navy during the 4 Anglo-Dutch Wars between 1652 and 1765. The VOC flag always flew on the lowest level.
The gold painted balls above and below the flags are called "trucks" and they are used on a mast above and below the flag to keep water from seeping into the mast. Some rigging is also sometime attached to the trucks. Trucks painted gold represent the relative wealth of the ship owner...the more trucks the wealthier the ship owner!
Ab Hoving suggested that I shrink the Prinzenvlag in size and add another flag or pennant at the bow, which I did. I'm using the generic VOC logo on the flag at the bow. I may experiment with different color flags. I will probably do another pass at the Amsterdam flag as well.
REVERSED Gemini_Generated_Image_p0wiszp0wiszp0wi (1).pngDutch_East_India_Co.jpg
9. Build Log - "Smalschip," 17th Century inland cargo ship from plans by Ab Hoving.
Done building the Smalschip, but not yet done completing the build...
I have redone all four flags and reduced the number of trucks on my Smalschip. With the skeleton rigging done and the vessel needing just some minor tweaks (I am going to re-do the rudder braces on the keel - I don't think they look proportional to the stern of the ship) I'm coming to the end of this build. I enjoyed giving my Smalschip an identity through its 4-flags: It is a ship from Amsterdam, during the late House of Orange-Nassau / Prinzenvlag period (1630's to 1650's) with Dutch Republican ambitions and deployed as an inland cargo vessel of the VOC, the
Vereenigde Oost-Indische Compagnie.
I really enjoyed the paper and cardstock method and I very much like the way Ab Hoving taught his variant of the method in his books "17th Century Dutch Ship Models in Paper," and "The Ships of Abel Tasman." I would say I'm a "convert" to the method and I plan to scratch build 3 more ships using the paper and cardstock method: The "Witsen's Pinas" 17th century Dutch warship / merchant vessel from plans by Ab Hoving, The "Jaght Heemskerck" 17th century Dutch oorlog-jaght from plans by Ab Hoving in "The Ships of Abel Tasman," and the "Staten Jaght Utrecht" from plans by Ab Hoving and Gil McArdle in "Scratch Building the Staten Jaght Utrecht." All from SeaWatch Books.
But while I'm done building the ship, I am still waiting on my 1/48 scale French Marines who I ordered from a shop in Poland to populate this Smalschip. I think they can be used as Dutch marines, although the year Michel de Ruyter formed the first Dutch marine corps was a bit later in 1665 during the Second Anglo-Dutch War. Until my French Marines land in Philadelphia, I'm going to populate my Smalschip with some 1/48 scale human figures in the next entry.
Here are some pictures of the final build of the Smalschip:
10. Build Log - "Smalschip," 17th Century inland cargo ship from plans by Ab Hoving.
While I wait for my 1/48 scale French Marines (3D printed) from Poland (it may take several more weeks), I am going to populate the Smalschip with some Dutch Amsterdammers who are also "Oranjegezinde," or House of Orange loyalists. These 6 sailors are so Orange that they ARE orange. They can also be called "Hollanders" because Amsterdam is in one of two Holland provinces in the Dutch Republic. While these Oranjegezinde are not sailors, per se, they represent a cross section of people walking down streets of Amsterdam today. Ab Hoving says the Smalship is usually operated by anywhere from 5 to 7 people working the sails, but with the skeleton rig my Amsterdammers are just along for the ride.
11. Build Log - "Smalschip," 17th Century inland cargo ship from plans by Ab Hoving.
Build Log COMPLETE! Finally!
I started this build a few months ago when I fell in love with Ab Hoving's approach to paper and cardstock modeling. As I've posted earlier, I like this method so much that I plan to build 2 more of Ab Hoving's ships from scratch using paper and cardstock: Witsen's pinas and the Jaght Heemskerck, and my own local 17th century Dutch oorlog jaght, the Kalmar Nyckel.
I know Mr. Hoving doesn't want to take credit for it, but he has introduced a new generation of model builders to follow this method in his books "17th Century Dutch Ships in Paper," " The Ships of Abel Tasman," and "The Statenjaght Utrecht." I've thanked him profusely for inspiring my work and getting me hooked on the Dutch Golden Age of Sail, from the "Duyfken" to the "Admiraal Generaal."
It took an embarrassingly long time to order the proper scale figures for my Dutch smalschip. First, the European supplier of my first sets of French Marines at 1/48 scale lost my package. Then I ordered some 1/48 German Luftwaffe officers and some WW2 U.S. Navy officers and came up with 7 good figures for the smalschip.
Then I did the math and realized that my Dutch smalschip was actually 1/72 scale instead of 1/48 scale. (I know, rookie mistake!) So I will use the 1/48 scale figures on my next build (the 1/48 "Onrust (Restless)" and just yesterday I received my set of six 1/72 French Navy officers. I was not able to find actual historic Dutch figures, so I painted the French Navy officers using the color scheme from a much later era, that of Dutch naval officers during the 3rd and 4th Anglo-Dutch Wars (1772-1784), with white breeches, black bicorn hat, blue coats and black boots.
I generally dislike painting figures (which is why I no longer build in plastic). But I wanted to honor Ab Hoving's advice about using scale human figures in his models:
"Adding human figures can work out well if done carefully. One of the advantages of adding figures is that the scale of the model suddenly becomes clear to the viewer. The human size works as a reference." From Ab Hoving - "Dutch 17th Century Ship Models in Paper," pg. 51.
The little French Naval officers were quite tiny, so I barely painted them, and will probably remove them when I put the Dutch smalschip in my display case. I think I will have better luck painting the 1/48 German and U.S. officers since they are larger and more detailed.
So now, we are officially moving on from the Dutch / Hoving smalschip. Going to finish my 2 half-hull models of the Herreshoff "Shadow" next. Then a wood kit-bash of the 1614 Dutch "Onrust (Restless)," in 1/48 scale, which we visited at the Connecticut River Museum on our vacation earlier this month. Then onto a birthday build of the "Staten Jaght" 1/48 wooden kit from Dusek-Mamoli. Then who knows...maybe some more Herreshoff or maybe some more Hoving? It will be a busy Summer and Fall at the Ignatius27 workbench!
