Good morning Peter. Firstly your AL-FI for the outriggers with eyes on them is legendary. I always imagine what you will do to make the rigging work with the split hull and your engineering is superb.
Secondly - what a fabulous tradition. At least this mayor slipped that herring down….. ROTF . Lovely pics. You live in a cool place.
Lastly: I love the detail in your rigging of the Mizzen sail (fabulously made Peter).
Prodigious little Balder being built Peter- shot.
Cheers Grant
Hi Grant. Thanks you very much for this very nice words and compliments!
About your ‘2nd-line’: Vlaardingen is the place where I was born and where the Balder is moored. A large part of my family lives there, but I left in 1975. I live in Woudrichem, and that isn't bad either. A beautiful, compact fortified town at the confluence of the Waal and the Maas, which continues as the Merwede.
This water also flows partly past Rotterdam and Vlaardingen towards the North Sea. Who knows, maybe I'll manage to moor the Balder in Woudrichem someday. Woudrichem is, after all, also a fishing town, albeit related only to inland salmon fishing. Every two years, they hold 'Fishing Days' there.
The lacing lines of the shrouds between de deadeyes on the Balder are attached in a way that I have not seen before, in part:
The fixed end with the knot is attached to the inside front of the upper deadeye block. After the 3rd pass-through in the lower deadeye block, the working part is first secured with 3 bindings to the adjacent pass-through.
Then it is inserted from the inside out through the opening just above the upper deadeye block between the shrouds. Subsequently, it is laid counter-clockwise behind the shrouds, after which it is threaded back through the front. The remaining end is then secured with 2.5 loops to the front of the lacing strip with 2x2 bindings.
So a challenge to make that in 1:50 as well .....
In my report on the Bluenose, I once referred to this binding with various threads - 0.12 mm Serafel - as bobbin lace making.;) Well ...... this is bobbin lace making for advanced students.:rolleyes:
After the stitches, first secured the upward running end with the 3 bindings and made the wrap around the shrouds:
Next, secured the 2.5 loop of the running end with the 2x2 bindings:
And finally, the 2 ratlines on the outside of the lacing ropes:
Unlike all the others, these 2 ratlines were secured not with black bindings, but with the same light-colored bindings.
Thanks to the macros: still a few small loose ends to tie up.
Up to the other side.
It is great to see the progress of the model and the joy you have building it and sailing the 1:1 version!
Makes me eager to continue my own build. Though I think I can not reach your level Peter.
Thanks for the compliments and nice words, Rob. Have in mind: it's not a competition of making the best model. Every one makes his model on its own level and the fun is: the making of the model! With sharing and showing our progress we can provide each other with ideas.
Hey Peter,
Had to do some catching up on build logs. She is beautiful!
Thanks for catching you and the compliments, Dean.
Looks like you’re close to being finished?
Only ‘just’ the Main mast and Jib boom with all the stays, lines and furled main sail and jib ………;) Ah, and the lifeboat on the aft deck.
"Mizze-ion Accomplished". The Mizzen mast is completed.
First in detail and then zoomed out.
Also managed to tighten the rigging of the shrouds on the starboard side:
And was able to lay the loops in the running end and secure them.
After that, all lines were tensioned correctly and secured. And fitted with the coiled lines.
At the 3 cleats at the foot of the mast, it requires a bit more squeezing with lines than on the 1:1. Because I cannot lay lines on the belaying pin rack on the starboard side. Therefore, some lines were combined on some cleats.
At the arrow that made me happy: the planned splitting of the rigging with the small magnets works! The rigging stays taut.
A bit from a front angle:
The sheet of the mizzen topsail has also been installed. That is a kind of continuous line that runs through 2 blocks on the gaff, with both ends secured at the foot of the mast. I will try to describe setting the mizzen topsail and mast below. Hopefully, I can clarify this next month when we go sailing with the Balder.
According to the old specifications, the topsails are set on the starboard side.
The sail is first secured on deck to the detachable topmast.
-The starboard end of the halyard, which runs over the sheave at the top of the mizzen mast to port, is then secured to the topmast at approximately one-third o the way up.
-The tack is a loose line that is secured to the underside of the topmast.
-As the sheet, the piece of line running diagonally down along the mizzen sail is secured to the clew of the sail.
The topmast with topsail is then hoisted up along the starboard side, past the mizzen sail, gaff, and peak halyard.
Once the topsail is set, the clew comes to rest just above the end of the gaff. Then the clew is tightened with the sheet via the block at the end of the gaff. The sheet runs along the gaff to a block under the gaff's claw and is then secured at the foot of the mast.
If the wind comes from starboard, the topsail presses partly against the peak halyard. If the wind comes from port, the sail becomes loose.
A photo from the book 'Uitgezeild' on page 132 of the Katwijk KW.105:
The mizzen at approximately the same angle as my photo.
A overall picture:
The work at the front with the mainmast and jib boom is next.
And a comparison picture:
Even with my 14mm fisheye, it didn't work out well. The problem is that the starting point is the shot on the left, taken with my iPhone. Next time, I should use a photo of my model as a starting point and then try to capture a comparable 1:1 representation.
