Need someone to print small parts
Jimsky
Administrator
Administrator
Forum Moderator
Brooklyn, New York USA
Greetings, fellas!
I find myself in a bit of a predicament. My grandson's Spyra electric water gun has gone on strike, leaving us high and dry and completely defenseless in the summer heat.
As the designated household engineer (a title no one asked for but I somehow earned), I was promptly volunteered to fix it. Upon performing surgery on this marvel of modern water warfare, I discovered the culprit: a tiny pump gear that had given up the ghost.
After some digging around online, I managed to track down a 3D printer file for the part. So here's my ask: does anyone here have access to a 3D printer and the willingness to save both a water gun and my reputation as a Granpa can fix everything? I am absolutely willing to compensate for your time, materials, and shipping.
And if you happen to be in Brooklyn, NY, I may even stop by in person — though I promise to leave the (broken) water gun at home. Attached are a few .stl files (not sure if they are usable).
Jim,
Check your local library! Mine has several printers and even a laser engraver that you can use for very very little. Also see if there is a makerspace nearby. They would have printers.
Rob
The library is a very good idea. I have one nearby to ask.
i am running the print file now print 4 pieces should be done in a couple hours and i will print them later tonight or Friday morning and send them Friday afternoon. You should have them by Tuesday or Wednesday
Thank you so much. I really appreciate your help, and I'll find a way to make it worth your time and effort.
Just saw this. Glad Dave was able to help. Just an fyi - he printed those in plastic, which has structural integrity. I have a resin printer, which is good for detailed models, but is not good structurally, as it’s very fragile. So anytime you need a part for functionality, you want plastic! ;)
I am trying to get some mouses printed using the file from this forum. The local commerical printers I have contacted say the pieces are too small for them. They can do an 11mm mouse but I want some smaller ones also - I can of course accept less detail on those! If I do not get any sense from local people, is this something you could print? I would pay, of course!
Very well done Dave, I congratulate you for kindnesses, as a Grandpa myself I understand the urgencies. I also like the suggestions of going to one's nearby library. Awesome thread. cheers Richard.
Greetings, fellas!
The man who builds fantastic models needs help. Release the Kraken! Call or e-mail Justin (Mr. Darivs Architectros) sure spelled wrong, or as we know him as the man who does not sleep. Have you not seen what he is doing to his SOS build!
string printers or filament printers are limited in how small they can print small items with fine detail require a resin printer.
i can try a print but the STL file will not download.
I got the file OK. I just cannot find anyonw who can print it! Ideally I woud llearn the CAD progran and modify the size of details...
