Rob, I had to laugh at this one - and so true! Your BN is looking great!In order to give them the look of being caulked, I took them and used a pencil to darken the edges. I this this by stacking them in groups of 5, holding them together with a clamp and darkening the edges. I found this process about as interesting as rat lining.
Rob, I had to go back and mention your post. Not only did I miss Gary's build but I apparently didn't learn much from my Dory/Pram builds! My BN planking transition at the keel was challenging and required some rework. Lesson learned!In his build Gary Brinker used 1/4 X 1/16" planks for his garboard. He actually used 2 rows of these bigger boards. I think I will do one for the Garboard and then go back to the 1/8 X 1/16 planks. The plans show the garboard extending from the sternpost to almost the E bulkhead. I have some 1/16" sheet and I cut out 2 planks from it.
Bill thank you for your kind comments! What I have been impressed about is that reading and looking at all the various build logs is that each is done a bit differently. I have learned from all of them. I have been following your log also and I have to say your ship looks great!Rob, I had to go back and mentioin your post. Not only did I miss Gary's build but I apparently didn't learn much from my Dory/Pram builds! My BN planking transition at the keel was challenging and required some rework. Lesson learned!
Once again, your BN is Looking great!
Gary Brinker in his you tube series did not taper his quarterdeck, it looked fine to my eyes. So I figured, why not?Nice, Rob, looking great! Though I did taper my quarter deck planks, I did briefly ask why!
A nice closure of the deck, Rob. And with ‘some’ sanding the deck will come alive.I finished the last Strakes on the foredeck. The last 2 fit tightly and had to be sanded down a bit.
Decking of the foredeck is finished.
As you can see from the previous pictures the deck itself is very rough. The planking is certainly not as well planed as the hull strakes were. I do not know if this is because the strips are so narrow or just poorer quality wood. It will require a lot of TLC to get nice and smooth.
Thank you Peter for your support!A nice closure of the deck, Rob. And with ‘some’ sanding the deck will come alive.
