Yesterday I received some samples of ropes from company "Modellbau Takelgarn"
link to english web-page here: http://www.modellbau-takelgarn.de/englisch/
Beautiful material on the first view (and touch) ...... I will report more in detail asap
View attachment 44873 View attachment 44874
PS: The big advantage with rope-material is the fact, that due to the light weight the postage costs, also international are very low !![]()
Hi Knut, I used the latest revised plans for the frames. The bolts are the same diameter as 20g wire. That would be 0.81mm.Tnx Mike, can I ask you, did you use pattern from the latest revised version, or you use
pattern from the previous one when you made the frames.
What is the thickness of the bolts in the frames (mm)?
