The whole model is interesting... need to rig those 4 guns under the upper deck so I can get some sort of accomplishment feelingRigging the Xebecs is fun.....something different. Nice work on those blocks and hooks. Cheers Grant
Details make the model- bravo. Cheers Grant. On the tackle I know British cannon have the double block hooking onto the bulwark and single block to the cannon? Maybe the French invert, I’m not sure- maybe check this out before all 17 are done. Cheers GrantThe tackle is in place on the carriage...
The excess rope was twisted around cascabel (or pommelion)
then brought back ... to make few runs around..
.. and brought forward a bit to make it ready for a final stage...
The other side received the same treatment...
Here I used crocodile clips to keep the rope tight..
Then the excess rope was rounded around gun tackle and breeching in some form of quadrant shape that will hold gun tackles and breeching ropes on both side, making a frapping..
That is it for today... 17 guns more to go
Happy modelling.
Yes, several different type are used... and big fingers do not assist at allImpressive tweezer skills!
I thought I have it correct but now you make me think... let me doublecheck...Details make the model- bravo. Cheers Grant. On the tackle I know British cannon have the double block hooking onto the bulwark and single block to the cannon? Maybe the French invert, I’m not sure- maybe check this out before all 17 are done. Cheers Grant
So much to be admired in your build and the way you present. -- Apologies I may have missed it earlier on but are those 'Ropes of Scale or home made?'The tackle is in place on the carriage...
Happy modelling.
Thank you... hopefully no more mistakes..So much to be admired in your build and the way you present. -- Apologies I may have missed it earlier on but are those 'Ropes of Scale or home made?'
Thank you, much appreciated.Thank you... hopefully no more mistakes..
These specific ropes are from Ropes of Scale and blocks are from Dry dock models.
Cheers
Now we are talking....! Fabulous.Have completed all 4 guns
And start fitting process of an upper deck... have to protect that hard labour with something
Happy modelling.
Cheers, thank you..Good morning. Ahhh....she is coming together really nicely. Kudos. Cheers Grant
