Well, Eric, so much of this kind of modification project is super-tedious repetition, however, if you stay the course and remain consistent, then you will never regret the extra effort. You're doing a tremendous job!
Thank you for the kind comments... I looked at your build log, and all I can say is "WOW"!!! Very impressive....Awesome project, I see a lot of similarities to my Vanguard/Superbe kit bash project — I’m so jealous of your 1:100 scale thoughfantastic detail, craftsmanship and paint techniques, really look forward to following your build!
HiI have finished planking the interior of the starboard side. i.e. planking the inside of the bulwarks where the eye can peer into. Looking at the black deck ledge for the forecastle, you can get an idea how the sheer line diverges from the deck line.
I am happy with the planking. You may notice above the square QD gun ports, I had to do... not sure of the carpentry term... a series of planks that were cut halfway in width to seat the next plank above without having to taper a tiny, sharp point. It was the only way I could think of that might be hostorically plausible.
This photo shows the standard kit rear bulwark with four (five?) sheer steps compared to mt SR1671.2 with three sheer steps.
And this last photo shows the kit bulwark positioned exactly where it would go, albeit mostly hidden behind my modifications...
Guy, thank you for the comments! I have your document, and it has been an exceptional resource for me to refer back to over the last several years.HiYou did a very beautiful work in re-creating the planking....
This kit has two main issues, and it isn't the fact that it only has 14 lower gunports .....It'is about its hull curve, its depth and its overall shape length wise; You fixed the rear part, but it needs a front curve (much smaller) too; the depth of the hull can be fixed by simply cutting off the part under the lower wale off.....As for the number of gunports......Can you read French? I can send you a document which will give you the details about the ships history that I reshearched for a couple of years and with many headaches; its 125 pages apprx.
