- Jan 26, 2017
Peter, since you’re still at the early stage, let me suggest something: the gap between the lower and upper deadeyes looks a bit too small. If you double that distance, it will look much more realistic and visually pleasing. The photo below from the real ship.
I noticed that too, but I thought you might not want to remove the lower deadeyes, so I didn’t mention it. Re‑doing the upper deadeyes is much easier. The spacing between deadeyes was usually set at about three times the diameter of the deadeye. This proportion allowed the lanyards to work properly and gave the shrouds enough room for proper tensioning. Also, having the upper deadeyes positioned above the level of the main rail doesn’t cause any issues in terms of accuracy.I think the problem is that the lower dead eyes are too high. I will not be taking those off.
Thanks Rich. I appreciate your popping by to see my build.Beautiful, inspirational work. Thank you for posting.
-Rich
Your welcome Peter. Believe me, even this will make it look better!I may have to compromise and settle on twice the diameter spacing. Lots to think about...
Good morning,Thanks Rich. I appreciate your popping by to see my build.
As an aside, have you considered using a signature here at SoS? That way anyone viewing one of your replies can easily navigate to your own build log. I supply two links in my signature. One takes you to the start of my build log. The other to my most recent post.
Hi Jon, my email is in the wild, so not concerned, it is richfairfull@gmail.com.Rich, I have your log. I copied it to MS Word for my personal use, by eliminating chit chat and any side conversations. If you want it let me know and I will send it to you either through personal email or message through this site.
Jon
Enjoy your day off, Peter!I also placed an order for a clip hackle pliers that will make re-rigging the shrouds easier.
Why don't you prepare the shrouds off the ship and then pass them over the mastheads from above? As far as I know, you haven't permanently secured the topmasts in place yet. I prepare all my shrouds off the ship, and it makes the job so much easier.
If you take a look at my post number 882 and the posts following that one on my log, I explain how I did it there.
