USS Constitution - Model Shipways
Man, oh man, is this time consuming...
To redo just these four shrouds took way too many hours.. I'm not sure that it's actually faster to do this off the ship. The clip hackle pliers should be in today's delivery from Amazon. I'm going to try those tomorrow with the shrouds on the boat. There's got to be a faster way.
It was worth the effort, and I think the result turned out really well. The only way to get through the rigging quickly is to rush it and cut corners but if you want to do it properly, you have to invest the time. I started my rigging back in November 2025, and I’m still working on it today. That’s just the nature of the job: it demands patience, but the reward is seeing the rigging come together the right way.
Keep it up, Peter, you’re on the right track!
Thanks Mustafa, I think things will go more smoothly after I get a bit more of that learning curve behind me.
This is my seventh sailing ship model, and believe me, the more you learn, the longer the process takes. ;) My Essex model had almost the same level of detail and workload as the Constitution, yet I finished its rigging in just six months. With Connie, it’s been nearly a year and I’m still working on it. The reason is simple: I keep learning new things along the way and trying to apply them to the build. :)
Isn't that the truth. For me it's an endless process. As I discover new things, I drift away from actual model making. But eventually I get fed up and move on from that topic. I do use AI too but I have learned that you have to double check information because AI makes up things. It's unreliable and although helpful can take a long time to give you a workable solution. It also goes into logic loops which are sometimes hard to get out of thus wasting time.
I tried it both ways. While there's not much of a difference, it is still slightly easier to do the rigging off the ship. The clip Hackle pliers helped in both cases.
I did learn that trying to do four of these in one day is pushing it. I started to get antsy. As a consequence I'm not a hundred percent satisfied with some of the knot tying, but I'm going to live with the way it is.
I'm always antsy! Impatient by nature. That's where this ship modeling hobby has helped me... forcing me to be a patient man. No hurry in finishing.
I had never heard of Hackle pliers and must have missed Tom using them on his ship, but I'm not a fly fisherman, so that would explain it. If I follow what you are doing, though, this may be similar to small alligator clips that I use to hold rope together when needed. Thumbsup
I like the way these shrouds and deadeyes came out, Peter. I know you were cursing through the re-do, but it was worth it. Nice work. Ratlines next? Enjoy!
