Tuesday, October 28, 2014
Last monday I did nothing but today I started with good will to finish the inside of the bulwarks, removing , as scheduled, the excess of plywood toptimbers.
Initially I started using a method that produced few dust and which consisted of a blade of a small hacksaw for iron. I only used the blade, without the bow, and to use it I covered the ends with tape. Then, holding the blade folded properly, I started to cut the plywood in excess.
The method worked adeguately but then I had to sand and trim the corners with the deck that was impossible to achieve well in any way except by using abrasive blocks and wood cutters.
Then I wanted to try to use the belt sander BSL 220/E presented in one previous message and I immediately noticed a positive difference . . no effort and pace.
Of course, the bad side was the dust, in fact produced in great quantity, so much that I finally decided to leave and to complete the last remaining toptimbers tomorrow.
I spent the time I had left to suck the laboratory with a vacuum cleaner.
Below two pictures of the front of the hull, showing the inner sides of both right and left bulwarks nearly finished . .
01 Brick%20by%20JackAubrey/P1100050_zpsa78bcf51.jpg
02 Brick%20by%20JackAubrey/P1100047_zps6ba96ebd.jpg
Instead at the poop there are still five toprtimbers per side I have left for tomorrow, which, however, give an idea of the work that had to be put on the track to get rid of the excess wood.
Finally, having already done much dust, I sanded adeguately the top of the bulwarks leveling the three layers of planks: this was a job that came with the belt sander incredibly ease: it is a tool that I highly recommend, of course for those who can afford it. .
03 Brick%20by%20JackAubrey/P1100048_zpsf1050203.jpg
04 Brick%20by%20JackAubrey/P1100049_zpsa806d014.jpg
All for now, until next time, Jack.Aubrey.
