Dremel Drill Press Milling.
Just to join the conversation this how I set up my X-Y table for my Dremel drill stand. I haven't done any extensive milling, I"ve just used this to mill flat spot on the Jib Booms for my Enterprise build. I had tried sanding, filing but wasn't satisfied with the results. Being a novice builder it's learn as you go and use what works.
So far I'm satisfied with this setup.
