Outstanding work! Where do you buy black hornbeam?Yes, I decided to replace this pillow-blocks for anchors ropes with scratched parts. They are made of vacuum coloured
hornbeam, as ebony is expensive and much more hard to get.
Thanks, Gennaro!Outstanding work! Where do you buy black hornbeam?
Many thanks Koreets and Jim, much appreciated.Hello @Gennaro One of the suppliers, I am buying 'black hornbeam', is our member @bibigon (Sergey). Please write him an email msservice@list.ru, he will be glad to help you.
Stunning work as usual. What kind of glue do you use to secure rope around double blocks?Still preparing to rig the guns...))
Thanks, Gennaro. I use cyanoacrylate glueStunning work as usual. What kind of glue do you use to secure rope around double blocks?
Thanks for the tip, Koreets. In the first picture, blocks look varnished. Once I tried using CA on varnished surface and reaction occurred, looked like white spots. I assume you glue the ropes and when CA is dry, apply varnish. Sorry for bothering you with my silly questions, but I'm in the process of rigging carronades, and any advice from experts is more than appreciated. Thanks again.Thanks, Gennaro. I use cyanoacrylate glue
I varnish/tone the blocks after assembly, when the ropes are glued.Thanks for the tip, Koreets. In the first picture, blocks look varnished. Once I tried using CA on varnished surface and reaction occurred, looked like white spots. I assume you glue the ropes and when CA is dry, apply varnish. Sorry for bothering you with my silly questions, but I'm in the process of rigging carronades, and any advice from experts is more than appreciated. Thanks again.
Thanks, Maarten.Marvelous work.
What did you use to secure the rope coil you made? Shellac?
The HypoCement is to secure the coil on the desk.Thanks, Maarten.
I use HYPO Cement glue
