This is the difference between me and you, Maarten!After planking the hull attach the plywood stern piece, steam it in the correct shape before fitting and when fitted cut out the frame.
Dear John,G'day Alex, don't cut the stern frame
Hi alex,
It is strange this frame is different. As you wanted to ad the rear cabin it is no issue as you cut it out anyway. After planking the hull attach the plywood stern piece, steam it in the correct shape before fitting and when fitted cut out the frame.
OMGAlex when you put the beams across they will lift the deck to the right position,
Yes, sure. I do follow Maarten's case. But I was somehow puzzled with this stupid issue with the stern. Yes, I will do as you said.G'day Alex, I didn't realize that you were going to build in the rear cabin, but if you are Maartens advice is good
Of course, it's all because the VOC company entered the Chinese market. The history always repeats itself, first as a tragedy, then as a farce...Your process of cutting the hull in two did also happen in reality in the 16th and 17th century.
