- Jan 9, 2020
Dear All
The good news is that it is the start of the Chinese New Year Celebrations aka Spring Festival (not that there is much chance of Spring - it's far too cold for that!) and hopefully I will have some time to work - uninterrupted - on the boat. Nevertheless, I still managed to squeeze some work in last night after work, and this morning before work.
No matter how much careful persuasion and fiddling with the torsion bars I tried, I just couldn't eliminate the slight warp that developed in the hull. The extremely flimsy stringers are definitely at fault here as the bulkheads are very sturdy and solid. Unicorn could well use some more substantial stringers in future, as it would improve the overall rigidity to no end. So ... I had to try something else and opted for a different approach. A chopstick was lobbed off at a slightly oversized length and wedged between the two bulkheads at the bow. Voila! Warp gone! I then simply boxed the chopstick to make any unwanted movement impossible. I know it is rather a crude way of eliminating the problem but sometimes a "big hammer" approach is all that works. (see photograph below).
Next, a few pieces of laminated wood were attached to the bow and stern bulkheads to minimize the deadwood area. They purposely extend too far over the sides to allow shaping to follow the curvature of the hull. This should make the planking of the sides easier and also provide more grip for the side planks. (see below).
With the hull now straight and true, it was time for my first ever attempt at planking. The first plank was laid down and all I can do now is to wait for tonight for the glue to dry before I can continue the process.
But solving the problems is half the fun.!
