**VIEW THREAD HERE** |
Fantastic detail work on the gunport's. Hope you don't mind if I copy it.Second coat of black aft and on the trim pieces along the rail. 2nd gun port (counting from the bow) covers installed.
View attachment 130851View attachment 130852View attachment 130853View attachment 130854
Really nice fit on the planking. No waterway needed!Poop deck planking complete. The trim piece on the front is 2mm square stock with the top edge rounded off and stained with Minwax golden oak.
Really liked your gunport take. Wanted to try the same approach but for some reason the distance between the top of the port and the trim piece is much smaller on my model so had to do just the hinges.Second coat of black aft and on the trim pieces along the rail. 2nd gun port (counting from the bow) covers installed.
The hatch makes sense don know why I didnt think of that I have the ladder going down then put stanchons at the corners , just may have to go back and follow your leadWorked on the companionway and the ladder today as well as the capstan. The companionway is all from scratch and I thought it could use a hatch cover too, no way it would just be open to the elements with no way to close it. The hatch cover is not on the plans but I like how it came out so I'm keeping it.
The main element of the capstan is from a mini kit but I added the whelps.
The last pic is the first kevel, combination sheave and belaying pin.View attachment 132052View attachment 132053View attachment 132054View attachment 132055View attachment 132056View attachment 132057View attachment 132058View attachment 132059View attachment 132060View attachment 132061
Having just acquired the Rattlesnake myself I have been pouring over any and all build logs of this great little ship trying to get as many ideas as possible before I commence the building of mine. Still have to finish the Pinnace Virginia before I start, but it doesn't hurt to do the research.![]()
Really liked your gunport take. Wanted to try the same approach but for some reason the distance between the top of the port and the trim piece is much smaller on my model so had to do just the hinges.View attachment 132359
TKAM a word of warning, I started the lifeboat and found out that wood they used dont like wood glue, dont know what it is I can soak it in water forever but if you put wood glue on it, it curls up. and actually not real happy with the kit
