I am m pretty much sure they are the same just the model numbers are different for the two continents
Yes - you are correct - here are the actual available machines shownG'day Zoly, they are entirely different models, I had the MF70 before and it is a smaller less powerful mill plus you cannot use it as a drill press as you can with the one I have now,
Best regards John,
WOW, you guys sure have impressive workshops.
My work space is both cramped and a hotchpotch. The only time I clear the tabletop is when I have something too big to fit on it without something getting in the way.
After this post there should not be any excuse for others thinking their shipyard is too messy for show![]()
"Spring is in the air", in Down Under. Spent last few days clening the unit from ceiling to floor (Spring cleaning).
Took photo of workshop while I can, because it will soon look like it did in post #14.
A messy workshop shows you are doing something.Wow, Swabbie.
I can relate.
Looks almost as 'messy' as my workspace.
Peter mine looks like yours only more cluttered!l
My ship yard is finally completed. It has taken my son and I, over 4 week to complete the transformation and I'm very please with the result.
It it wasn't for my son who spent almost his 4 weeks holidays, helping me, I don't know when this would be completed.The only thing that I have to do is to make new labels for the drawers and to put labels on the toolboxes that are on the top shelf above my socket sets etc..
I was more of a foreman than a labourer, Jon didn't want it any other way.
These 2 photos below show the whole area and the only difference is that I took off the dust sheet that is on the RC building cradle.
The next photo is the my new spanner and sockets shadow boards.
The next series of photo shows the 2 lights can move both vertically and horizontally, so I can have the light source where I need it the most.
And this shows how the vertical adjustments works.
The photos of my dust both florescent light shows it can slide back one forth on two tracks.
All of my tools which makes dust that have an dust exhaust, (would you believe have different size mouths), so we used a 32mm PVC pipes and permanently attacked it to the exhausts.
And for my dremel router table, we made an extractor which works brilliantly.
An overall view of my dust boith
I have only one vacuum hose and on the end a rubber joiner was used to go over the 32mm PVC pipes.
All of the power for my tools are plugged into a power board and the end which goes to the outlet on my extraxtor/vacuum cleaner. When I operate any tool the vacuum turns on and stays on for twenty seconds after the tool is turned off.
Above shows the corner of my shipyard with the cane rubbish bag and my silver cylinder for my spare timbers.
This final photo shows the drawers where I still have to put name tags on so I know what is in, what drawer.
My son, kept on bagging me about the small step ladder, which I use to look in the top drawers. I told him it's not easy to be 'vertically challenged'.
Hope that you all, like my new shipyard.
Happymodeling
Greg
well equipped,what is Admiralty project you are working on?
Upright on the table is my current project Boudriot's Ambitieux 1680, on the shelf in the back is HMS Warrior 1781. I stopped working on that one a few years back for personal reasons, you can read about it here. http://www.hmswarrior1781.com/well equipped,what is Admiralty project you are working on?
Thanks Janos, I may get back to it someday, I certainly learned a lot from it. It has some compromises (as built from the Romero Practicum), it is made with the Harold Hahn style of frame construction which is neither prototypical nor historical and is extremely wasteful of wood ... and that has always bugged me too. but who knows, maybe....Jeff,
I understand your feelings regarding Romero and fully agree with them. However, fortunately, Warrior is still there. Are you going to continue with it?
Your workshop looks great and so do your models.
Janos
