And here is the bow margin plankThanks Zoly I will use this most probably.
Oh...got it, it is plans from different source. Thanks Mike.There is no Anatomy of the Ship about the Ontario.
Thanks Uwe,this is how copper tree nails look like on the L’Amarante from Roland Vlahovici,he used teak as me for deck planking.Hallo Zoly,
I am using usually 0,6mm in scale 1:48, so I guess in your scale would be 0,8mm a good looking diameter.
Nevertheless I would first try it on a dummy deck - especially if you want to use brass or copper wires, so to get a feeling for the nailing.
And I would prepare a bigger dummy area, maybe 5 to 10cm area......
I have the feeling, that the copper wires with the dark timber of the deck could look like very good - (nevertheless on the original ship they were made out of timber) - pure question of taste
I am ,I mixed up copper with brass,I will use brass,also Roland used brass tooHi Zoly,
Copper will oxidize over time, but I would use wooden treenails. But as Uwe has mentioned, it just a matter of personal preference. Copper treenails would bu much faster, though.
Amazing deck Zoly. Nicely done.Hello guys
Finally I finished the lower deck planking ,I will do a really deep overall sanding ,I planning to use copper wire for tree nailing,I need some help with the wire diameter for 1:32 scale.
