Hi,no nothing yet ,Deck fittings need to constructed and will be glued so the should not be sealed yet.Also the treenails have to be done too.Did you alreday applied anything to the deck? I maen any lacquer or wax.
Thanks!Very nice result so far, I can't wait to see how it gets after adding nails and poly.
Thanks Nigel!!Brilliant Zolly!It will look even better when a finish is applied,the paper has a semi dusty colour to it at the moment,the finish will make it sharper and black
Kind Regards
Nigel
Thanks Don ,I just slept 2 hours after workBEAUTIFUL DECK ZOLY, JUST ONE QUESTION WITH ALL THAT YOU ARE INVOLVED IN TO THE BETTERMENT OF SOS I MIGHT ADD,,,, WHEN DO YOU SLEEP. Don
Go easy on the Pepsi Fuller! LolZoly - PLEASE go easy with that power sander my friend.![]()
...or get that Jim (Byrnes) disk sander or better yet...Jim's table sawZoly - PLEASE go easy with that power sander my friend.![]()
Hi Nigel,exactly that my thoughts too,thanks.Zolly if I understand your question correctly,the red areas will be made up of normal horizontal planking.
Kind Regards
Nigel
