Thanks Janos,I am not going to fix it,I can’t,at the ster I will cover with planking the upper deck over the cabinLooks good! How are you going to solve that width problem at the aft windows?
János
Yes ,the side galleries will be slightly larger a little bit ,hardly visible once the upper deck is installedOK, I can see now, the side galleries will make up for the difference
János
Here is an earlier post on edge bendingGreat progress, Zoly!I am guessing, that novice model builders will have the same question as myself: How do you manage to bend the planks along the edges? Did you make a jig or bend each plank individually?
