Vasa is a real time-machine, indeed. I did not know they allow inside already. Great!Vasa
Dear @Maarten, do we have 4 different size anchors at RC? I think mine anchors are all of the same size...The info I have is of 4 different size anchors
Hi Alex, in the kit they are all te same size but this is incorrect. I will modify 3 of them.Dear @Maarten, do we have 4 different size anchors at RC? I think mine anchors are all of the same size...
Oh, yes: I checked the book, and the pictures and the text (p26) indicate 2 different sizes (2+2). How sure you are that all 4 of them were different?Hi Alex, in the kit they are all te same size but this is incorrect. I will modify 3 of them.
oh, I thought that they started to allow visitors to get on board...By is the way vasa is not allowed onboard but the museum is fantastic.
Hi John,G'day again Maarten, do you have any link to any information about how many anchors the Royal Caroline had, and how they were rigged, I'm getting conflicting references,
best regards John.
Thank you Maarten, for the quick reply, I think that I will keep all four the same size, I know when I built the HMS Investigator she had two of the largest anchors ready for use and another two slightly smaller lashed to the channels, and also a much smaller one lashed to the main channels, I will rig the cables to the two at the cat heads, but leave the others without there cables, makes it easier for me and members can see two different ways,Hi John,
Most of my sources are 17th century. What I could find on the Royal Caroline is that all 4 anchors were the same or two different sizes.
See below text about the anchors in the aots book.
In the drawing of the aots book they draw two different size anchors a one ton anchor and a 3/4 ton anchor. See the drawing below.
This is the road I take, two different size of anchors.
On the place of the anchors there is also a lot of contradiction to find. In the aots book the say the lighter anchors were stored on the cat head with the bowers on the gun wales. Other sources tell the bowers were always ready to use with the lighter anchors on the gun wales. The latter is the approuch I will follow.
This is what makes the model unique!
Thx gents for your comments.
I am still working on the focsle to finalize everything there so I can fit the beams, bullwark and deck planking.
So this evening I made the mast step in the main deck for the forward and main mast.
In the kit lasered rings are supplied. I turned these on the lathe to give them a smaller outside diameter and some tapering on top.
To simulate the individual pieces I first draw a template on a piece of wood and with 2 droplets of ca glued it on top.
With a knive I then cut the lines following the template to simulate the individual blocks.
The cuts I fill with pencil before sanding it with steel wool and oil it.
Below all 3 stages together with the double blocks for the gun carriage.
And fitted the fwd mast ring in place
Some time ago I already prepared the windlass booms
To store these I made some brackets of 0.8 mm brass wire, bend and hammered into shape followed by burnishing them black.
The brackets I fitted into the deck beams, identical on the ps and sb side.
Just to store the booms properly when finished working with the windlass.
A view over the deck into the focksle.
And with the windlass booms in storage place.
The finishing around the bowsprit will be fitted when placing the bowsprit in a later stage.
