Maartan,
As always exceptional work.
Oh, I guess the thick one is for on the top of the wooden railing around the kings room.
Many Thanks for the information - I will give these products a try...... I need better results (used until now Krick)Hi Uwe,
I use Ballistol Nerofor for brass.
For Iron I use Ballistol Schnellbrunierung
First I sand the items with sand paper or steelwool.
Then degreasing with Ballistol kalt entvetter.
Depending on the parts they need 5 to 15 minutes with every now and then stirring with a brush until they are black all around.
After that flushing in water and cleaning with a cloth
Hi John,hello Maarten here are another couple of pics, it is 500mm long x 3.5mm x 2mm,
Hi John,
I have checked but dont have this thick strip, only thin copper strips in several sizes. In which package was this included?
Mast rings? For these I have thin copper strips.It was included on one of the boards that had the masts on,
It felt like that.Incredible detailing added with the waterline marks - it must have taken a brave man to burn the first one into the ship!![]()
To "burn" the model !!! How hard was really to make this step? Because making a step like this is definitely not reversible !!!! Looking very goodToday a small update. At Action I recently have found a set of letters of 5mm for burning. I used these for burning the waterline marks. The 5 mm is for my model 15cm in reality which seems to fit.
On a Dutch 17th century shipwreck of a pinas which you can visit for free in the port of Den Helder Netherlands I have noticed to ways of showing these waterlines.
On the PS side like this.
The V on its side with dots for the 1, the bottom of the V is the waterline.
On the SB side of the same wreck the normal roman numirals.
Why there is a 4 at the bottom I dont know, ot seems to be at the height of IV feet.
These are the numbers I am using, I have sanded these back to the outer contours of the letters.
Then heating above a flame as they did not fit into my solder iron. Stil some fine tuning needed on the heating proces.
And on the on the PS stem.
I have also added all bolts for the stem and beakhead construction.
