HMS Royal Caroline kit ZHL 1/30
Hallo Maarten,
which stuff you use for the blackening? And maybe a short description which working steps to blacken you make? Really good result!!
Hi Uwe,
I use Ballistol Nerofor for brass.
For Iron I use Ballistol Schnellbrunierung
First I sand the items with sand paper or steelwool.
Then degreasing with Ballistol kalt entvetter.
Depending on the parts they need 5 to 15 minutes with every now and then stirring with a brush until they are black all around.
After that flushing in water and cleaning with a cloth
I buy it here in the Netherlands online
but checked it and they also have a US site.
Looks like in the US they dont have the burnishing fluids.
I know most people in the US use Casey Brass Black.
Hi Uwe,
Many Thanks for the information - I will give these products a try...... I need better results (used until now Krick)
Today a small update. At Action I recently have found a set of letters of 5mm for burning. I used these for burning the waterline marks. The 5 mm is for my model 15cm in reality which seems to fit.
On a Dutch 17th century shipwreck of a pinas which you can visit for free in the port of Den Helder Netherlands I have noticed to ways of showing these waterlines.
On the PS side like this.
The V on its side with dots for the 1, the bottom of the V is the waterline.
On the SB side of the same wreck the normal roman numirals.
Why there is a 4 at the bottom I dont know, ot seems to be at the height of IV feet.
These are the numbers I am using, I have sanded these back to the outer contours of the letters.
Then heating above a flame as they did not fit into my solder iron. Stil some fine tuning needed on the heating proces.
And on the on the PS stem.
I have also added all bolts for the stem and beakhead construction.
Mast rings? For these I have thin copper strips.
I have those as well Maarten, this piece was just just laid on the board and sealed in with the plastic cover along with everything else, maybe it was put in by mistake,
best regards john.
To "burn" the model !!! How hard was really to make this step? Because making a step like this is definitely not reversible !!!! Looking very good
Interesting Maarten,I had been considering how to depict draft markings on Saint Philippe and had considered this approach amongst others.This is a detail omitted by many modellers but is easily visible in the scales we are both working to.I also have to contend with a "bronze" insert underlining each set of numerals on Saint Philippe.
I have decided to address these details later because I want to consider all options but it is reassuring to know you can actually buy such things as the numerals for Pyrography.I have done a brief search on Google to find a mass of things available for a whole other hobby in it's own right.
Kind Regards
Nigel
