- Aug 14, 2018
I have started making, bending and preparing the beams for the quarter deck. The kit uses a side plank with already cut notches for the beams, but since I am extending the Q.D. I have instead run a strip of 1x1 mm along each side to support the beams and let me place them where I want them. The beams are notched at different heights, gradually decreasing, the notches allow me to adjust them to the correct height and so the planking touches all in turn.
Before I plank across the top I decided to pimp the 'great cabin' a bit. I cut and glazed two four pane windows in the entrance doors. And whilst not wanting to make it into a dolls house I will a one or two pieces to give a feel of depth. And flushed with 'success' after making the galley flue I decided to start with a Georgian side board. I know people where shorter back then, but even so there will not be much head room in the cabin. Slushy scales out at a huge for his day at five foot ten, yet as you can see his head will be through the deck no bother.
B.t.w. he recons that sideboard will next be seen on the Antiques Roadshow, giving a couple of centuries!
Here are some pictures, including the first fitting of the beams.
Cheers JJ..
Cheers JJ..
