A 143 feet long Dutch warship from 1681. Cardstock [COMPLETED BUILD]
Hi Ab, amazing what you have done with paper!!! The sails above are spectacular. I see you sprayed with starch, did you have a hairdryer on them to get the billowing effect as you sprayed them with starch? I'm guessing they were done in place on the model as all the rigging seems to be pulling correctly.
The sample is already in the mail. :)
Hi Ab,
Today I received the Batist cloth I ordered and compared it to your sample.
Your sample is finer in structure and slightly less transparant.
For the scale you are building your sample is definately the better one, for my current 1:30 build mine could be a good option to test.
I will send you a sample in return.
Have a nice and healthy 2021.
Hello Maarten,
Today I received your sample. Thank you. You are right: batist is less close woven than Navara Fine lawn and much more transparent. Of course it depends of the scale you are working in, but for the time being I prefer the latter over all the other samples I held in my hands so far. I'm content with the three meters (!) I purchased.
Here my new years wish:
Ab
Again a beautiful picture with a view at s lands magazijn in Amsterdam, love it.
Also to you and your wife a fantastic new year as to all other members of SOS.
Many Thanks for
Hi Ab,
the comparing the two cloths directly together - with this we can really see the difference.
This brings me to the opinion, that for the "normal" scale of 1:48 the Navara Fine lawn from Whaleys Bradford would be the best choice - I will order some material.......
Perhaps you are interested in witnessing one of my builds. My system is fast and cheap and it hardly makes a mess of the workshop. Consider it as 'modelbuilding light'.
It always starts with a draught. Many times, if there are no useful drawings available, I have to develop them from scratch, like for instance an original specification contract. My loyal Belgium friend Rene Hendrickx works my suggestions out in the free downloadable shipbuilding program Delftship, so I can print the lines and body plan.
I glue the frame prints to stiff card and cut them out. I use a stuff called grey-board, available at your art-supplier, but any stiff card you have in your dustbin will do.
I double the frames below lower deck level and cut slots in them to fit the deck.
I'm not sure if these pictures come from this particular project, but since there is little difference they will do.
Then the whole contraption is glued together.
Then the lines of the ship are decided by placing the lower wale. This is a tricky part, as there are very few points that can be used as a reference. Small deviations will end up in a terrible mess, so care has to be taken.
View attachment 140560.
Then the frames are covered by strips of cardboard. I use a kind of soft and fluffy material, called 'wood board'. At the same time I removed the parts of the frames above deck level and doubled the inside with another layer of wood board.
Then I use filler to get rid of the angles. The nice thing of wood board is that it can be sanded (up to a degree) without delaminating. I also cut the lower gunports.
After dry-fitting the upper decks the upper gunports can be cut out. Don't bother to look at the pleasure vessel in the fore-ground, this is the first picture of the warship I made, showing it in a stage ready to be planked.
All this makes a very quick process. It only took a week to get to this stage. In fact I hardly noticed I was making this vessel, because I work on six or seven hulls at the same time and I completely forgot to take pictures of this one.
The whole hull below the upper wale is 'planked' with strips of wood imprinted, self adhesive white plastic, called c-d-plastic. Very cheap and it works easy, because with the use of a hair dryer they can be bend in the necessary curves.
After a primer I paint the hull above the waterline with Humbrol 64 and below with 28.
After a week of drying I brush a dark brown, called Van Dijks Bruin (from a tube), over the upper part. Immediately after that I wipe the brown off with a soft cloth, leaving paint in the wood print, so a suggestion of real wood is achieved.
Now I can finish the details like the carvings and painting. I found a ship that matches the size of this model, called Akerboom (oak tree), with the right number of guns.
The rest is a simple rigging job.
I always prepare my masts up to the stage that they can be fitted with sails on them. That way I can work on them, without forcing myself too long in the same attitude, leaving me with sour arms and shoulders. Another thing that has to do with age is that I leave both my deadeyes and my ratlines white until they are ready and I can finish them with a dark paint.
When I will work on the rigging again I will keep you posted. I don't know when that will be, because I am a bit inconstant nowadays. There are a lot of projects waiting for me.
Hallo @Ab Hoving
we wish you all the BEST and HAPPY BIRTHDAY
Enjoy your special day - great to have you on board
Maybe the wrong thread, but since I donated seven of my models to the Archaeological Museum 'Huis van Hilde' in Castricum, Holland, I missed the sight of a nice fluit. The house seemed empty without one. So I built me a new one. The hull was no problem, it only took me three weeks, but the rigging is always a challenge. Repetitive and boring, but in the end the reward is always so good. You end up with a lively model, only by adding sails in a specific situation. Dutch sailors sat on the yard, one hand for the ship, one for themselves.
Judge for yourself.
Fluit_Hoorn_3.JPGFluit_Hoorn_5.JPGFluit_Hoorn_6.JPGFluit_Hoorn_7.JPGFluit_Hoorn_8.JPGFluit_Hoorn_9.JPGFluit_Hoorn_10.JPGFluit_Hoorn_11.JPGFluit_Hoorn_12.JPGFluit_Hoorn_13.JPG
What a great way to model a hull.
You seem to have many innovative ways to produce your models , and in particular , you are very proficient with using all manner of card stock .
Very well done indeed !
Judge for yourself.
View attachment 249406View attachment 249407View attachment 249408View attachment 249409View attachment 249410View attachment 249429View attachment 249430View attachment 249431View attachment 249432View attachment 249433
These little guys are looking busy !
Great action model !
Action model is the right word. Love these working sails men. These ships got only a few men on board the sail the ship. Looking to these pictures you can see how hard they had to work.
Congratulations finishing this Fluit
