- Aug 8, 2019
Maarten, I see that you applied the center sections of the master ribbands without the whole thing on the slope. You left out the height level. That's not how your master ribbands come out correctly, is it?
About the rising of the orlop deck there is something in Kamer's essay ("N.H. Kamer - De voorsteven van 17-eeuwse zeegaande schepen" written in "Tijdschrift voor zeegeschiedenis 20 (2001)") . He shows a table where he makes the comparison about the values given by Witsen, Yk and Grebber (whoever that may be), the difference of values is probably to be found about the time period the writers are talking about. Ships before 1650 showed a higher rising of the sheer. After that this was less. Yk is talking about ships from a later time frame. For every 10 feet of length between the stem, the rise was indicated in the table. From that data you can then determine the starting point of your master ribband on the bow.
Finally found an answer. I checked this in Winter's drawings of my Dutch 2-decker and it comes pretty close to the measurements of Witsen.
Those Dutch builders where smart in there building method. With only a certer with measurements of certain points of a ship they where capable to build those big ships with just pieces of ropes and gravity.
