Reordered the Lobster Smack, going to finish the one I have, then do a second build, hopefully profiting from the errors and goofs made on the first one, which was quite a learning experience. This time I will use shellac on the hull as Bob Creek suggested. before sanding and painting.
I will also brace the weakest part of the stem, now knowing where they are, and try using my soldering iron for plank bending, as well as soaking in boiling water for 6 minutes, to see which works best.
I will solder the brass rudder parts, probably before installing them, and contemplating installing the rudder before the decking.
The fairing needs some better work, and more patience.
I have been jumping in and out of SOS, looking at other builds, hopping to lean from them.
