Thanks GregReally nice work. I also have this kit but will be quite a while till I start it so in the meantime I will follow yours with interest
Hallo @MarcMarseilleSalut Gilbert
Est ce que les instructions de Mantua Panart sont fiables?
J'ai eu beaucoup de problèmes avec le San Felipe de la même marque, avec des mises à jour entre les plans et le document qui ne correspondaient pas.
Hi Gilbert
Are Mantua Panart instructions reliable?
I had a lot of problems with the San Felipe of the same company, with updates between the plans and the document that did not match.
Marco
You did a very fine paint job, Gilbert. The ochre looks better!Hello all
Significant progress on the Americo Vespucci as you can see on the pictures below.
I need to add the second row of windows on the port side and add them on the starboard side.
Good morning Gilbert. You make stunning models. Good luck with your surgery. Cheers GrantHello all
The windows on the starboard side are now installed.
The hull is now completed, and I am now going to get started on the deck fittings.
I'll do this as soon as I am back from hip surgery planned for early next week
Cheers
Grazie Pietro
Cambiare il colore dell'oro in ocra è stato un vero dolore, ma ne è valsa decisamente la pena.
Hi Gilbert, I hope to do a good thing for the model you are building. FrankHello all
I am now back home, recovering from my hip surgery that took place last Monday. I was wondering if I should post a picture of the post-surgery Xray in the "purchased shortly ago" section
First thing I did was to change the way the bolts are showing on the ochre color plates, just under the decks.
This is the way it looks based on the Panart instructions.
As you can see, this is not super accurate and I decided to insert small nails in each of the holes, to simulate the bolts.
This is now the way it looks (need a second coat of ochre paint)
After that, I worked on the stern doors and fittings.
Pictures below
