Just goes to show that if you are going to build POF or POB then you need to be able to think laterally for solutions to problems!I tackled a problem with the transom today. Because of problems with the lofting of the after cant frames, the frames did not line up with the transom. The last 4 frames tended to curve inward, like the bow, rather than flow straight to the transom. The only solution was to cut each of the final frames and "bend" them outward to meet the planking which is already in place. The frames were then glued to the planking,and when the glue is completely dry, I'll fair the inside of the hull where the "surgery" took place prior to planking the inner bulwarks. It was REALLY difficult to chuck a cutoff wheel into my Dremel and cut the frames off after all the work that went into building them! Fortunately, I'm planking both sides of the model down to the wales, inboard and outboard, so the "fix" will not show.
The first photo shows the problem, the second shows the cuts and the third shows the frames straightened out and glued to the planking.
Now on to the port side! View attachment 168852View attachment 168853View attachment 168854
You wouldn't believe some of the 'mods' I had to make when building 'King's Fisher', but it all came out OK in the end.
Nice build Doc - following with great interest!
Ted
