Good morning. Spot on. I love the wood contrast of the window frames and the stern planks. Cheers GrantFinally finished the transom. Ready to start planking the hull.
View attachment 381411View attachment 381412View attachment 381413View attachment 381417
There were two ports which were cut bigger than they should have been. I didn't replace the planks on these. I decided to try to fill them in to see if that would work. They came out okay.
Good morning. Oh boy, those oar ports certainly created some consternation. Great job on the redo’s and determination to get these right. Respect. Cheers GrantBecause I was bored....There were two ports which were cut bigger than they should have been. I didn't replace the planks on these. I decided to try to fill them in to see if that would work. They came out okay.
I made some wood power by sanding the same wood I'm using on the hull.
I packed the power in the holes then doused it with thin CA..
Then I used the wood powder and PVA to level off the holes.
Nothing great but it worked well enough for me. Here's the larger holes I filled then recut.
