BLUENOSE - YuanQuing by Donn Farr
I AM STILL HERE DOING FRAMES, FRAMES AND MORE FRAMES ABOUT HALF DONE, I HAVE A QUESTION HEINRICH ON FRAME NO 27 IT IS DIFFERENT THEN THE OTHER ONES HAVE A PICTURE IT IS THE PART WITH THE QUESTION MARK AND THE COMPLETED FRAME IS DIFFERENT HERE IS THE PICTURE. GOD BLESS STAY SAFE ALL DON
Hello Don, Just checking in with you, haven't heard anything for a while - are you still building frames and having fun? have you got a "frame skeleton" yet?
HISTARGAZER, OH YS HAVE BEEN BUILDING FRAMES, FRAMES AND MORE FRAMES AS OF TOM ORROW WILL HAVE 40 FRAMES DONE I THINK THERE ARE 17 MORE TO GO, PUTTING TOGETHER THE JIG AND WILL POST UPDATE TOMORROW I HAVE NOT STARTED THE BEVELING YET BUT WILL DO A SAMPLE TO SEE IF IGOT IT RIGHT AND I HAVE THE QUSTION OF FRAME NO 41 ETC IS IT A DIFFERENT WAY TO PUT IT TOGETHER DO NOT KNOW IF I AM EXPLAINING IT PROPERLY ON THE BOW SIDE FRAMES THE ACK ENDSOF THE FRAMES LINE UP LEAIVNG 2 LINE FOR BEVELING TO THE EXTERIOR SIDE BUT WHAT HAPPENS TO THE STERN SIDE FRAMES NO 41 ETC THE BEVELS HAVE GO TOWARD THE STERN CONFUSED ABOUT THAT SO NEED HELPO THERE. GOD BLESS STAY SAFE YOU AND YOURS DON
OK HERE ARE SOME PICTURES FRAME 14 GLUED TOGETHER BAGGED FRAM 17 GLUED TO GETHER ON MY FRAME BOARDS HAVE 18 AND 19 READY WAITING TILL MORNING TO DRY THEN GLUED TOGETHER FRAMES NO 20 THRU 40 BAGGED AND STORED READY FOR FRAME 41. GOD BLESS STAY SAFE ALL DON
Don the assembly of those frames looks very good to me. Obviously one will only be able to really tell once you have done the beveling. Maybe one of the other builders can chip in with Frame 41 onwards, because I am not nearly there yet. As you know, I have had another big issue on my hands that needed sorting out. That took up a LOT of time.
Hey Don, frame 41 is put together exactly like frame 40. The bevel is changing direction now that you are past midships so now every frame will be bevelled towards the stern. The extra line you see on the drawing on frame 41 is the laser etched line on the frame itself so you are understanding things right!!
If this is not clear let me know and I'll try better to explain.,
HI DON, NEED TO PROCESS THIS RIGHT NOW, I WILL SEE IF I CAN EXPLAIN, ON THE FRAMES THAT BEVEL TOWARDS THE BOW WHE I PUT THEM TO GETHER THE REAR GETS LINED UP, THE FRONT IS ON THE SECOND LINE DOES IT STAY THE SAME OR CHANGE SORRY FOR BRAIN NOT WORKING YET. GOD BLESS STAY SAFE YOU AND YOURS DON
Don, the difference on frame 27 is due to the change in deck height. Leave it staggered. I don’t think it’s is supposed to be beveled. Someone ahead of me can verify.
Checked the plans, that is definitely where the deck elevation change occurs on frame 27. Front side is lower deck, back side is upper deck. All frames after that, 28 and up, have the new elevation on the back.
Happy Birth Day Don, May you have a great day, I hope that you get the biggest piece of cake and also that you receive all of the new toys that you have hopped for.
Regards Lawrence
I fully agree with that! Happy Birthday Birthday-CakeExplosionBottle
