Bomb Vessel Granado 1742 - Cross Section - 1:32 Scale - Scratch Build by DocBlake [COMPLETED BUILD]
Thanks, Rich!
The next step is to cut out the mortar pit beams. These support the pit deck itself, and in turn, rest on the upper support beams of the shell room. There are notches (really shallow dadoes) for both on each beam.
I milled up some 3/8" thick swiss pear and glued the beam templates to the wood with rubber cement. They were then cut out using the scroll saw. The mortar pit boundary timbers fit in the dadoes on the upper surface of each beam (red arrows). It's important that these line up exactly so I cut the beams a little long and snuck up on the final length using the disk sander. There should be no side-to-side play in the beams when fitted properly. Then I cut the dadoes on the under surfaces of the beams (green arrows) after marking each one individually so the fit on the upper support beams is precise. The beams have poly but are not yet glued in place.
Thanks, Don!
After gluing the mortal pit support beams in place I began work on the mortar pit itself. The first parts to make were the boundary timbers that define the outboard boundary of the pit deck. These are swiss pear timbers with a rabbet ploughed into them to accept the secondary planking layer.
There a two layers of planking. The primary or lower layer is thick: about 9 scale inches. The secondary layer, which lays on top, is thinner and has a recess cut in it for the rotating platform the mortar sits on.
Holly can get mold growth which can stain it a bluish gray color if there is too long a delay between cutting the logs and kiln drying. I had a piece with that stain in it. Rather than chucking into the fire wood pile, I used it for the lower planking, since only the ends of the planks can be seen and they don't show the staining. The photos show the lower or primary mortar pit planking and the boundary timbers. Note the discoloration of the holly.80.jpg81.jpg82.jpg83.jpg84.jpg
I built the secondary mortar pit deck off the model by edge gluing the planking together. I then located where the center of the circular cutout would be and drilled a hole. I transferred this location to the primary deck by putting the deck back in place and marking the primary deck with a nail through the hole.
I whipped up a little jig to hold the secondary deck in place while I drilled out the circular recess with a Forstner bit. The secondary deck was glued in place.
Well executed - very sharp and crisp cut - Looking very good.
In the beginning I was by myself a little bit sceptical about the different typs of wood - but in the meantime I like it realy very much
"Painting with wood" - Very good
ThumbsupI built the secondary mortar pit deck off the model by edge gluing the planking together. I then located where the center of the circular cutout would be and drilled a hole. I transferred this location to the primary deck by putting the deck back in place and marking the primary deck with a nail through the hole.
View attachment 212137View attachment 212138View attachment 212139View attachment 212140View attachment 212141View attachment 212142View attachment 212143View attachment 212144View attachment 212145View attachment 212146View attachment 212147
amazing work
I started work on the upper deck by rubber cementing the deck beam profile templates to a sheet of 3/8" swiss pear. I used the scroll saw to cut out the beams, and sanded them smooth. Each beam is 12 scale inches square in profile!
I cut the beams slightly long and used the disk sander to sneak up on the final width. I'd like them to fit with no side- to-side play, but the fact was that due to the tumblehome of the top timbers, I had to make the final beam length a little short so they could fit into their notches on the clamps. Any side-to-side play will be taken care of by using removable shims at each end at glue up. The photos show the beams resting in place. Partial beams #4 are not yet fitted.103.jpg104.jpg
A friend and collaborator, Joseph, is doing 3-D drawings of the plans and we are making changes to simplify construction for those less experienced. This includes eliminating the rise in the frames moving aft as well as eliminating the narrowing of the hull moving aft. He also drew up the deck such that all the beams, carlings, ledges and lodging knees were the same thickness (pictured). I decided to use stopped dadoes on the beams to seat the carlings. Thus the carlings would be thinner than the beams. I'll keep the ledges and knees the same thickness as the carlings, though, to simplify construction. I think it will look fines.
Rather than use a razor saw, chisels and a hobby knife to cut the dadoes for the carlings, I looked for an easier way. what I did was cut the dadoes all the way through the beams at a depth of 1/16". I then milled some 1/16" pear stock to the width I needed to give me stopped dadoes. These were glued in place and sanded smooth. Very easy!
Here is where I am. I've got all the deck beams notched and have started installing them from aft forward. Because the beams sit in notches in the deck clamps, they can't move. Fitting the hanging and lodging knees is really finicky if you want a tight fit. I'll add the carlings and ledges and finish the deck up to the forward end of the mortar pit. That's where the hardest part of the deck starts: fitting the beam arms. I cut them generously and left them a bit thick. They are so long that I have to account for the deck camber.
