Good morning Bill-that is a brilliant fix. (plank gaps included). When I saw your first pic it was like how do you fix that....fantastic.
Cheers
Grant
Cheers
Grant
Bill,Good Evening! Hope everyone is well!!
Made some progress this today; Fixed my "oops" - Companion way is now where it belongs. And started paring the bulkheads.
View attachment 289074View attachment 289075View attachment 289076
I may pull up 2 of those planks.. Not fitting as tight as I would like to see.
Ran out of sandpaper so I'll continue the paring tomorrow. I'll put up a couple of pics - (This is where I got carried away 5 years back and over sanded the bulkheads on the "Pride of Baltimore". At the that time I gave up and shelved the kit.
View attachment 289082View attachment 289083
Jeff T: Hopefully others will see this and avoid this mistake, lol!Bill,
I did exactly the same thing, putting in the bulkhead backwards so the hatch was on the port side of center instead of the starboard. I caught my mistake before I did the planking, but the fix was basically the same.
Good morning Bill. Good thinking to plank the midship cabin plywood makes a huge difference.The vertical pattern on the strakes looks fantastic. Well done. CheersGood morning Everyone! I completed the breadboard siding on the midship cabin. I will do this to the exposed bulkheads as well then airbrush them white.
View attachment 290122View attachment 290123
I have some LED flicker lights to install before starting 1st layer of planking.
Very nice job on the vertical planking of the cabin. I might do the same thing on mine.Good morning Everyone! I completed the breadboard siding on the midship cabin. I will do this to the exposed bulkheads as well then airbrush them white.
Hey Paul,I don't understand the black then white thing, so I am eager to see how it turns out and maybe learn something!
Hi Bill, I ordered this kit a few weeks back and it finally came the other day. I will leave it in the box for now while I complete my othe work in progress but I have watched your work so far and your suggestions. You do a great job and it definitely will be worth following your build. Enjoy.
I love the texture on that wood, I would dry brush it to bring out the detail. So I too am curious to see it after being sprayed.Good morning Everyone!
Hope this post finds everybody well. So I opened up the bow and started initial painting of exposed bulkheads and midship cabin.
View attachment 292965View attachment 292966View attachment 292967
I used a tamiya type of masking tape as my primary cover-up. I first airbrush all the surfaces with black primer the finish coat with white. This makes the line details really pop.
View attachment 292968View attachment 292969View attachment 292970
I'll apply the white finish coat next day or so.
Love your work, Bill.Good morning Everyone!
from these deck plans you can see there has to be a cutout to gain access to the WC/ lamp room and the windlass,
