This is a very interesting and unusual topic for a ship model Henry.
I have been to Burma for a holiday a few years ago before all the trouble started.
Your rice boat is looking like it is closer to the water. Nice work. Rich (PT-2)The mast supports are now fixed which will allow me to work out the the height of the support to keep the mast clear of the deck structure steering platform which size wise i think will work out ok. The real problem i have now is to cut holes for the poles or oar structure in the piece on the deck that runs along the outline of the hull it's proper name i forget i suppose when you make things from scratch without a plan you don't think you just go ahead and make it should have cut the holes before i glued it to the deck will use a pin vice and drill and see how i get on afraid to use the Dremel in case i go through the hull which would be the end i even made a 1mm chisel from an old jewelers file so this next step may take me some time.
View attachment 265654View attachment 265655View attachment 265656View attachment 265657
Like Rich said getting closer will now think about the rudder support and rudder then after that i will revisit the deck structure still plenty to do.
Interesting to see the sail is in two halves to get around the two-legged mast. This is a unique boat to have and will make a special model for you. Rich (PT-2)Now back have been trying to find a way to lead you to the site but everything i try dose not work trying for the last hour how i reached the site in the first place i don't know but i've bookmarked it shows how clever i am. The site was trying is glartent.com----- Burmese ( myanmar ancient boats ) which has some beautiful paintings same can be found in facebook again can't log into it will have to wait till grandsons come so that's me. Would really like to read Charlie Than ( PDF. Myanmar traditional boats ) have the site bookmarked Academia.edu again can't log in used to be able to but i was getting emails every 5mins so i stopped it. Would really be grateful if anyone can help. Some of the paintings seem to have the same design as the paddy boat but with a modern bow third photo.
When the rain soaked that large of a sail it would be quite heavy. and stress the long yard. You have a very interesting project in your hands. Rich (PT-2)Rich regarding sails my first impression like others was they are huge but when i stop to think i lived in the tropics for 17 and a half years various locations and never encountered any heavy winds not even during the monsoon winds were light if at all that would explain their huge size. Yule in his book gives us details of the yard 130 feet long the sails were attached by rings to a rope attached to the yard the area of cloth 4000 square feet and made of common cotton used to make cloths imagen a tee shirt that size makes you think. The mast with wooden rungs just like a ladder dose away with ratlines i think these boats were away ahead of their time would be interesting to know when exactly they were on the water maybe 18 cent. just hope i can do the model justice.
Your progress looks very nice. This is an interesting boat to watch emerging. Rich (PT 2)Still think the top mast is a bit big but comparing to pics and photos it's not far away i think the main + the top mast should not really exceed the length of the boat who knows. The yardarm must have a fitting to connect it to the main mast i don't think a half yard (it's end at center )would be lashed to one side of the mast i think the strain would be too much or like i think two halfs joined by a bamboo tube and hauled up like a normal mast(yard) surely someone knows the answer.
View attachment 269049View attachment 269050View attachment 269051View attachment 269052View attachment 269053
