Cazador Xebec - OcCre 1:60 [COMPLETED BUILD]
Thanks for the guidance!
I was thinking of putting some veneer on the carriage casting, but would be a lot of work. Also they seem to be too low, forcing the cannon barrel to aim up. I would have to add a piece of board to the top sides of the carriage to build a higher mount for the cannon. Or try to cut or file off the wheels and make wooden wheels larger in diameter. Regardless it will be a lot of work to turn them into something useable!
So it would be worth it to just buy some that have potential out of the box!
A few items come to mind when you build your own carriages:
There needs to be a longitudinal flat piece (Stool Bed) set on top of the rear axle for the use of rectangular and a wedge shape set of bolsters (quoins) that bring the muzzle down for the firing range needed. That bed is usually supported by a rod extending through both carriage sides.
Wheels are quite small: The larger is just forward of the cap square holding down the trunions. Smaller one is about in the middle of the stool bed.
Sides are splayed out according to the taper of the barrel but usually close to 2 degrees with a transom vertically set inside at the muzzle end.
Some carriages had an extension at the front/muzzle end which is radiused side to side so that the gun could be moved by crows to fire at side angles out of the port with that piece tight against the bulwark for stabilizing the gun as well. Sometimes chocks were used but they would go flying during the firing and have to be replaced. None were used behind wheels as restraint was the function of the recoil hawser and secondarily/much less the outhaul tackle which was not meant for that purpose and would go flying around creating a hazard as the bitter end was loose. Jean B. shows the French 74 gun Frigate with holes through the middle of the carriage under the barrel for the recoil hawser. Carriages varied a lot depending upon the barrel caster and separately the carriage maker across the years, ships, and armament desired.
I have recommended Building 18th Centry Naval Artillery by Dmaian Sieknoic, before and still do as a supplement to Jean B. Just a thought. Rich (PT-2) You will be much more rewarded by making your own than buying.
Finished all the cannon doors on one side. A lot of work actually.
To each one (24), I added a veneer in the sapelle wood the hull was done with, painted the edges black, drilled hole for eyelet, glued in eyelet, and added ring.
Then of course they were all glued on.
Taking a break from the cannon doors to build some hatches for the main deck.
Dear Dean.Why do you want to take ready-made parts again?Make the carriages yourself.I don't see anything complicated in this.Find a drawing, an image of guns from Le requin.Adjust it to your scale.You can view my carriages in the Mistique theme.Yes, I also ordered barrels from RBModel.Very high-quality barrels.
@Mr.Deep ... I agree the task is not that daunting, just VERY time consuming to build 20 carriages from scratch at this scale of 1:60, however it really depends on what degree of detail I go into on them. And at this scale I'm afraid I can't get too crazy with it. Anything would be better than the basic carriage castings provided in the kit, which are void of any degree of detail!
In conclusion, I hope not to take a month on building cannons, when I have many ships waiting to be built after this one. That doesn't imply I am rushing to finish, or that I am not willing to go the extra mile for a better end result. I just don't want to get too bogged down on any one aspect of the build.
So I will scratch build a carriage and see if I think it warrants the extra effort verses adding detail to the castings...stay tuned!
@dockattner ...
This is my face when I realized I have been tasked with scratch building 20 cannon carriages at 1:60 scale, because the provided castings are void of any detail!
Being able to find humor in challenges passed by is a great way to reduce stress and a shorter life. Well adopted as is the excellence of your build within the boundaries that you want. Rich (PT-2)
I have to be honest, I am not a slave to historical accuracy like some ship builders. I enjoy the hobby and do it for personal satisfaction and for something to display. Therefore I am willing to take personal liberties with my ships. I do however appreciate detail at scale. That is what I strive for most.
So I won’t be too concerned if my carriage is 17th or 18th century version, or whether it was the exact one used on a Xebec...this is a Spanish Xebec also, not the French Xebec most keep referring me to.
I’ll just simply make a carriage that incorporates all the basic design elements of the average naval cannon carriage during that era. After that I want it to look realistic within the detail achievable at scale. I could get very detailed if I chose to. But I’m going to build one to see what kind of work that may entail before I commit myself!
