Thank you! I carved out the corners using a #18 chisel xacto blade. I find for miniature work I can use it almost as a plane to gently remove sections of wood.Nice work on the support posts.
I have heard that many cobble stone streets in the city of New York were also made from the ballast! On Long Island where I grew up many of the streets were supposed to be made of crushed oyster shells. Oysters being a big product of the surrounding waters.Good old ballast rock. I have heard stories of old harbor town cobble stone pebble streets being made from ships ballast as they took on new cargo going from New England back to Europe. As cargo weight went in rocks came out!
While waiting for that to dry, I started work on the orlop deck waterways (which for some reason are called scuppers). Both building logs I have read to help me with this build have complained that these pieces of wood are too curved. When I tried fitting them one fit rather well but the other had a bit of too much curve.
Then to make sure things fit well I soaked the waterways in hot water and clamped them in place overnight to help then achieve the correct curve.
Remember they are closed on Mondays! Don't ask me how I know.thanks for the instruction link.
once upon a time modelshipways use to sell just the plans for almost all their ships. i see they dont do that anymore.
anyway, enjoy building this beautiful cross section of an amazing ship. im going to make a point of visiting her in boston this year.
happy new year
There are lots of resources for the Constitution available. Especially useful would be the "Modeler Resources - USS Constitution Museum". Between the (free) ME instruction pdf and the Modeler Resources, I suspect that you could obtain what is necessary to scratch build this kit. I used the section "Masts, Yards and Sails" during my build of the kit.nice job!
id love to scratch build this model. i wonder if i can buy only the plans?
great way to kick off a new year.
enjoy
You've got to love wood and how forgiving it is to our mistakes. Nice recovery. Not having the barrels in place may make it easier to fill some of the extra mast slot you have now.I believe the mistake is that I glued the mast footing about 1/8 inch too far back on the keelson. It was obviously too late to move the mast footing. So taking a #11 xacto blade I carved out a long slot in the front of the hole of the mast footing.
Of course doing this I again snapped the brace holding the mast alignment. Taking a tip from Jeff Ts build log I used some scrap to re-enforce the braces. You can note the mast alignment guide on the brace.
While this was going on I was also concerned that the berthing deck could also be out of alignment. After carving out the extension in the front of the mast footing I dry fitted both the orlop and berthing decks. The hole for the mast was also too small at the berthing deck so I enlarged it the same way I did the orlop deck. Doing this everything fell into alignment.
This is the good info I need to be aware of when I build my cross section.Now onward to the orlop deck or lowest deck in a ship where usually the cables were stored. The first thing I did was to stain the top and bottom of the orlop deck and as long I was at it the berthing deck with cherry stain.
View attachment 492535While waiting for that to dry, I started work on the orlop deck waterways (which for some reason are called scuppers). Both building logs I have read to help me with this build have complained that these pieces of wood are too curved. When I tried fitting them one fit rather well but the other had a bit of too much curve.
An angled cut had to be made on the waterways curving 1/16th inch from the top to a point on the bottom. I measured a number of points 1/16th inch along the top that will go against the wall. Then using my trusty #17 chisel blade, I used it as a plane and planed away the wood. When it was close to the angle I wanted I finished it off with sanding.
View attachment 492536 Then to make sure things fit well I soaked the waterways in hot water and clamped them in place overnight to help then achieve the correct curve.
You might ask Model Expo, they sell plans to some of their kits separately.nice job!
enjoy
