If you plan to rig sails and mount the guns you could show the gun ports open. If you don't have sails or they are not set , then perhaps the gun ports would be closed.
Hi Mike,If you plan to rig sails and mount the guns you could show the gun ports open. If you don't have sails or they are not set , then perhaps the gun ports would be closed.
Step #40, framing the interior of the gun ports.
The pictorial instructions show the material for item #40, the thickness and width and cut length ( 1 X 5 X 12mm), the length of that material in the kit and the number of pieces to be cut (56).Hi Uwe,
I've checked the cut profile plan and the rigging plan and the gun ports measure a nominal 12 X 12 mm. My gun port cutouts are approximately 10 X 10 mm. I did that in case I decided to use the commercial gun port frames in my post #180. I'm still thinking about that..
I found some photos of the HMS Victory which are demonstrating and showing what I wanted to express in my bad english
The lids are shaped to follow the curve of the hull. and no frame was visible from outside, when they were closed
View attachment 40714 View attachment 40715
The Hatch:
I’ve also learned to double check the instructions for a build part and double check the plans to verify dimensions.
More Tools: Sanding Detailers.
I’ll let you know how they work out.
They are looking interesting.....so please give us later your opinion....how much is the price for them?
